Denon AVR-X1000 MCU Shorted
  • mmartell
    • Oct 2013
    • 3189
    The MCU gets roasting hot when unit it plugged in, more so than surrounding components I'm pretty sure it's shorted.
    I can buy the MCU from Digikey but the it looks like it would need to be flashed with firmware and I don't have the jig for that.
    Can't find a parts unit to harvest from so that's out.
    Suggestions or do you think the HDMI card may have other shorted IC's from whatever killed the MCU and the unit should be parts-binned ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Denon AVR-X1000 MCU Shorted
    Came across an HDMI board from the sister unit (AVR-E300) and transplanted the MCU into the non-working board.
    Unit boots up and all buttons and knobs function but the unit goes into DC Protect mode after varying amounts of time but within a minute for sure.
    There is no sound produced at any time, and nothing from the headphone jack either. None of the output transistors are shorted.
    There is a very small voltage (4mv) at the bias resistor pair but there is a DC offset at all five speaker terminals of 300-500 milivolts!
    B+ and B- are at 57.3v and -56.7v and the 12v is steady.
    How to troubleshoot ?
    • mmartell
      • Oct 2013
      • 3189
      This might be unrelated but after power down and unplugging the positive rail goes to zero but the negative rail only falls down to -35.4v and stays there. Is there a bleed resistor for the negative rail I should check ?
      • mmartell
        • Oct 2013
        • 3189
        Still -35.1v after sitting unplugged overnight. How is this voltage designed to dissipate ?
        • budwich
          • Jul 2015
          • 3097
          I was just poking around with interest. don't know anything about receivers much more than recent efforts on a crown and onkyo, but I do have a couple of denons, hence my interest. I was looking at page 96 of the service manual, at where the -B is delivered to the main board. It appears to be going thru some transistor to get into the rest of the board. Is it possible that "switch transistor" has an issue and is leaking after the fact voltage into board even with shutdown. Related, I guess depending on the type of amplifier design, perhaps the +B and -B should be closer in value otherwise, there maybe some form of DC "left hanging around"... :-)
          Of course, I know nothing but just thought I would bounce some thoughts for you to ponder.
          • mmartell
            • Oct 2013
            • 3189
            I think you're talking about Q5702 ? I don't know what it's purpose is but I would think if it was meant to bleed off voltage there would be a resistor to ground and not a cap ?
            But yes if it's faulty I suppose it could destabilize the negative rail.
            And yes I was wondering if the voltage for the positive and negative rails should be identical, or if there is usually some mechanism to adjust them as such.
            • R_J
              • 9580
              Q5702 is just a soft start switch for the preamp section B+, it is setup to delay the B+ to the preamp section until after the main output is powered.
              Do the speaker output relays click in?
              If you are measuring voltage at the speaker terminals, that would suggest that all the speaker protection relays are energized (so the amp is NOT in protection) But it could also just be phantom voltage and not the actual offset voltage.
              I would check the actual offset voltage on L5101 ~ L5501 it could be that one output section is bad
              • budwich
                • Jul 2015
                • 3097
                One question, where did you measure the +B / -B values that you reported? I am not sure I understand RJ's comment about the q5702... if I read the schematic right, it is dealing with the -B side of things and not +B... but then again, I did say I have only limited experience on this.
                As for the differences in voltage, I would expect them to be close / very close. I don't believe its an "adjustment" (although could be) but more of something not right / happening.... almost like a diode / transistor difference somewhere... hence the previous question.
                • mmartell
                  • Oct 2013
                  • 3189
                  I measured B+ and B- at the collector of each output transistor.
                  I think RJ means Q5702 only conducts after C5708 is charged up (?) so that PRE B- line starts up AFTER the main B+/- rails are fully powered.
                  Still trying to find out why the rails are not exact inverse of each other...
                  RJ,
                  Yes the speaker relays click on. The amp stays on for up to a minute at most (usually much shorter) before clicking off with the infamous fast flashing power light. Going into diagnostic mode afterwards shows DC Protection was triggered.
                  There is no sound from the Tuner at all during that time.
                  I will measure at the inductors soon.
                  • budwich
                    • Jul 2015
                    • 3097
                    can you also check the input powers at cn503... just for comparison sake at the "source". I still think your "negative observation" is a good clue.
                    • mmartell
                      • Oct 2013
                      • 3189
                      I can't get to that connector during operation but you'll notice the schematic says both the Main B+/- run direct to the collectors of the output transistors with nothing in between (except for jumpers, maybe) so the readings should be identical.
                      • budwich
                        • Jul 2015
                        • 3097
                        OK... I see the "soft start" function for the pre-amp that RJ is alluding to... :-)
                        maybe doing some simple resistance tests at each amp (strategic / accessible points) and compare the results to see if anything jumps out.
                        missed your post... sorry but I agree with your statement.
                        are you able to get at / check the wiring options around the -B area... there are some jumpers near that area along with something like the "#18" which seems like potentially some form of "fuse link" maybe.
                        • mmartell
                          • Oct 2013
                          • 3189
                          I have here a similar, possibly the same main board from an AVR-E300. There are no #18 wires as stated in the schematic there are only traces bottom side of board which lead to the collectors of the output transistors for the negative rail. There are three jumpers used to get there all the same size from what I can tell. If one had no continuity I would not be reading anything at all the collectors.
                          I feel compelled to redo some of my voltage readings but cannot do so until later today.
                          Thanks for helping out, btw.
                          EDIT: I have tried using this main board in place of the one at issue but this board shuts off before the relays kick in IIRC.
                          • mmartell
                            • Oct 2013
                            • 3189
                            L5101-5501 all hover around 0.8v but go as low as 0.5 and as high as 1.1v on all channels.
                            The measurements were the same at the emitter resistors so I turned all pots down to minimum but the readings didn't change.
                            Also when the relays cut out and the unit goes to protection the readings at the emitter resistors jumps to positive rail voltage and begins to dissipate quickly but maybe that's normal ?
                            • R_J
                              • 9580
                              If ALL channel offset voltages (emitter resistor voltage) jump to positive, it must be something common to ALL channels. Are you sure you are not loosing the -B+ to the channels?
                              Do you have +12 volts and Pre-B getting to the preamp section?
                              • mmartell
                                • Oct 2013
                                • 3189
                                I don't know what you mean by that ?
                                Yes I have the 12v line and PRE B- getting to the preamp. And yes I agree it's common to all channels.
                                As stated earlier my B+ and B- rails are off by roughly the amount of the emitter voltage. Is that normal and/or ok ?
                                B+ = 57.5v
                                B- = -56.6v
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  have you checked the diodes in the connection jumper "pack" d5701 at the power input area. Perhaps the +B is shorted, resulted in a higher incoming +B causing a "differential".
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    That part is referring to the bridge rectifier making the B+ and B- rails. Could be leaking somewhat will give it a diode check.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      not sure whether you can... but in the DC detect / protect /activate circuit at the bottom of the main board diagram, there is a jumper (j5675)... which appears to bond the surrounds detection to the front detection. I am wondering if removing that jumper will allow you to determine if indeed both are having an issue or only one.... although you seem to indicate that you see DC on all outputs which then means it is further back in the circuitry.
                                      sorry just throwing out ideas... I know from my crown endeavor, I was looking at the negative side of the amp because of high negative values but it turned out that the positive side had the issue is that design.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Ya colour me confused. It seems to be affecting all channels. What was the problem in the Crown amp ?
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • BalkanBoy
                                          Dead Razer Blade 14 2022, shorted CPU?
                                          by BalkanBoy
                                          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                          I removed coil and injected 0.7V, it draw around...
                                          09-27-2024, 12:44 PM
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
