Hi, can someone help me find the schematic for this amp? Im having a hard time finding it. Trying to mod the vu meter lights to led. Please let me know if anyone has it. Thank you.
Optimus mpa 250
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
Assuming...7 Photos -
by ash91Hello gentelmen .... this is my first post and sorry for my bad english,
so my proplem is my laptop keep losing hard drive even if i but the
hard disk in the cady (the box that can replace the dvd rom with hard disk)
when i turn the laptop on the massage that said no boot media found pop on
the hard disk is fine and to be sure i try another hard
i also update my bios to the last update
the 5 volt is present on the hard connector on the motherboard
the dvd rom work fine when i but a windows dvd in it
also when i boot from flash... -
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... - Loading...
