Pioneer VSX-531
  • mferna14
    • Jun 2018
    • 1026
    Pioneer VSX-531
    Does anyone have the Schematics diagram for Pioneer VSX-531???
    The HDMI LED starts to blink & this is the protective mode. I checked all the Transisors array on the power transistor board, all the transistor seems to be fine, but as soon as I plug the cable into CP403 socket, the HDMI starts to blink. This cable is coming out of the main board at the botton where the big caps are located & out there too I do not see any short. Without this cable attached the receiver works fine & the display & all modes works fine. means something short???
  • madan1
    • Nov 2016
    • 682
    Re: Pioneer VSX-531
    Have you checked the schematics of the previous models?
    I'm sure pioneer uses the same power amp board in previous models. Most likely you will find and the schematics of the smart parts ( the mainboard(s) ) but with some ICs missing.
      • 21022
      Re: Pioneer VSX-531
      This service manual might help
      • R_J
        • Jun 2012
        • 9551
        Re: Pioneer VSX-531
        CP403 supplies B+ and B- for the amp outputs. You likely have shorted output transistors in one or more channels. Check the voltage on each pin of CP402, they should be near 0 volts
        • madan1
          • Nov 2016
          • 682
          Re: Pioneer VSX-531
          Hm, you just made me download some VSX manuals... damn, when I first saw "pioneer" and "8kg" for a 5channel AVR I immediately thought - class D amp!
          The lightest AVR with similar output specs that I've seen was 12kilos... but damn.. accounting and marketing departments at their best!
          Anyway... op, download the service manual from the link in the above posts and see how to enter the service mode. Try to see the recorded errors with disconnected CP403
          • andyb1712
            • Oct 2018
            • 41
            Re: Pioneer VSX-531
            Pioneer AVRs after 2015 are made by Onkyo and have equivalent models.
            The service manual for TX-SR373 has references to the VSX-531 so I think the schematic for the amp is likely to be the same.
            The TX-SR373 manual is available from ElektroTanya
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
            • JohnML1975
              LG 49UK7550PTA - after couple of hours screen starts to blink
              by JohnML1975
              Hello Forum team
              Have this TV; searched for the model and could not anything so thought I would share in here
              Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
              Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
              So I removed the covers, and could not see anything visibly
              Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
              07-25-2025, 10:48 PM
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
            • janos666
              Pioneer LX5090 - 2x Red blink after auto-shutdown
              by janos666
              I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
              03-26-2023, 11:20 AM
            • Caimano
              hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
              by Caimano
              MB G7AD-2G DAG7ADMB8D0 REV D
              Processor i5 8265U
              AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
              Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
              Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
              02-06-2024, 10:14 AM
