LG Xboom PK5 demo mode..probably
This topic has been answered.
  • tomodachi
    • Apr 2012
    • 603
    • Turkey
    Got 2 pieces of new LG Xboom PK5 bluetooth speakers for really cheap price, thanks to a friend. He told me these are demo products as it says on the box
    "Not for sales"
    Speaker powered by Type-C USB charger cable but not charging battery, I tore one down and checked the battery and charging circuit inside,all ok.
    Capacity remains at %10 and not charging above it to (I guess) keep battery from cycling and wearing effect since designed as a unit to stay on a store shelf for a period of time.
    You need to plug charger to make it power on, and once you plug charger you can't turn it off with power button because its totally effectless.
    Unit runs at full volume when powered, you need to adjust volume from source since volume up & down buttons not working.
    Obviously this unit is on demo mode, does anyone have an idea how to turn it in to normal mode ? any ideas will be appreciated.
  • Answer selected by tomodachi at 07-08-2024, 05:06 AM.
    tomodachi
    • Apr 2012
    • 603
    • Turkey
    Re: LG Xboom PK5 demo mode..probably
    Originally posted by tftcamilo
    Any suggestion. I have a pk7 with the same problem.
    Hey, I m here again with the solution !
    Finally found a retail version of PK5 and backed up firmware from it.
    did exactly as rcdavi3 mentioned here and result was just as expected.
    after reflash unit will work same as retail version.
    I m posting here the dump, its ok but belong to an older version.
    after reflash unit will work same as its retail version.
    Remember to update firmware after reflash, not only will update software, it will also increase volume to about %20
    To update firmware you need to install an app to your phone named "LG Xboom"
    any questions let me know
    Models that work with this dump;
    LG Xboom PK5
    LG Xboom PK7
    • petehall347
      • Jan 2015
      • 4427
      try using the reset hole in the rear panel
      https://www.lg.com/in/support/support-product/lg-PK5
      • petehall347
        • Jan 2015
        • 4427
        if that fails try this .
        Power off at the mains. Then hold power button on the top of the sound bar and the power on at the mains then
        release power button and it should be out of demo mode.
        • tomodachi
          • Apr 2012
          • 603
          • Turkey
          this didn't work, all that do is restarting
          this also didn't work, another thing I forgot to mention is without charger it starts and chimes but battery indicator light glows red and unit turns itself off. With a full battery it does same but with battery indicator green
          • petehall347
            • Jan 2015
            • 4427
            maybe there is a firmware update that might fix it ?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              if you have the app https://play.google.com/store/apps/d...xboom&hl=en_GB
              im sure if you go into settings there is a update section maybe this will update the firmware?
              • tomodachi
                • Apr 2012
                • 603
                • Turkey
                thanks for the suggestion, I did it but still not fixed, maybe I should find a good one and copy the firmware and flash it to mine
                • tomodachi
                  • Apr 2012
                  • 603
                  • Turkey
                  This speaker can't be hardwired to work as a demo right ?
                    master hoarder
                    • May 2008
                    • 12175
                    It's possible.
                    But it wouldn't make sense to hardwire anything. After all, why do that, when you can just take any production floor model, and program a Demo mode to activate by pressing some buttons in a certain sequence or by selecting from a menu. This is what many other modern electronics (like TVs, for example) do, so I don't see why they would try to hardwire anything.
                    • petehall347
                      • Jan 2015
                      • 4427
                      "Not for sales" might be they are broken waiting to be fixed .
                      • tomodachi
                        • Apr 2012
                        • 603
                        • Turkey
                        Originally posted by momaka
                        It's possible.
                        So true
                        I don't think so, the person I got them from said he has loads of these and they all have same issue, said he bought them from a bankrupted company
                        • tomodachi
                          • Apr 2012
                          • 603
                          • Turkey
                          Update :
                          I discovered that speaker s charging circuit working, on mobile application you can see current capacity, now its %100 percent full, but still don't allow me to use it, it turns itself off when turned on. But when connect charger it turns on its own
                          • tomodachi
                            • Apr 2012
                            • 603
                            • Turkey
                            Any chance to find firmware binary file I can reflash ? any suggestions ? I can reflash the firmware to its motherboard.
                              master hoarder
                              • May 2008
                              • 12175
                              Would be interesting to see if that indeed solves the issue.
                              Hoping that someone sees this and can get a firmware dump here.
                              When it comes to firmware, I usually throw in the towel - but that's just me: I prefer to stick to hardware issues only.
                              • tomodachi
                                • Apr 2012
                                • 603
                                • Turkey
                                haha thanks, I m also a hardware guy myself but gadgets nowadays piss me off with their strange firmware issues
                                • tftcamilo
                                  • Sep 2020
                                  • Brasil
                                  • tftcamilo
                                    • Sep 2020
                                    • Brasil
                                    • rcdavi3
                                      • Sep 2020
                                      I work for a major retailer which has the demo units for the PK7, PK5, and PK3. If you look at the bottom of the unit you will see SVC CODE: PK3.AUSDEMO
                                      These are firmware modified units from LG which will disables all controls other than "Enhanced Bass", prohibits Bluetooth, and battery operation. I the only way I have seen people overcome these firmware locks in the past is to open a retail unit, dump the firmware, open the demo unit and overwrite the NAND with retail firmware.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        So I guess that means we need someone who has a dump of the retail firmware to post it here.
                                        What a waste! I'm sure LG could have easily programmed the Demo mode inside as an additional option. So frustrating to see manufacturers do things like this.
                                        • tomodachi
                                          • Apr 2012
                                          • 603
                                          • Turkey
                                          LG Xboom PK5
                                          LG Xboom PK7
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
