LG Xboom PK5 demo mode..probably
This topic has been answered.
  • Mr.TaTTa
    • Jul 2022
    #41
    Re: LG Xboom PK5 demo mode..probably
    Originally posted by Blasphemer
    Hi, I have a couple of LG XBoom PN7 speakers, one of which was stuck in what I now know was demo mode, only works when plugged in, power button doesnt work, stuck at max volume and no BT. After scratching my head for a while I chanced upon the firmware file for the PK5 from here.
    I took the demo speaker apart and found the firmware chip, unfortunately it was only a 1Mb chip, so the PK5 firmware could not be flashed to it. I took the chip off of the board and put it in my CH341A programmer and read the hex from it. I really didn't want to, but I took apart my new fully working speaker, and took the chip from that board. However, upon reading that, it was completely empty with every value was FF. I didn't know whether I had fried the chip or somehow wiped it, and was calling myself a stupid whatever. Anyway, I put the chip back on the board and put it back into the speaker. It powered up perfectly!
    So now, with nothing to lose, I put the old chip into the programmer, read the data, saved it, then thought "what the hell" and clicked "Erase". It wiped all values to FF on the chip, I took the now "empty" chip and soldered it back onto the board, put it back together enough to test, and voila, a fully working speaker, works on bluetooth, connects together for dual play.
    So if you happen to see one advertised as having "Charging Issues" with the same symptoms as mine, you can easily repair it by merely wiping the chip.
    Tldr. If you have a PN7 stuck in demo mode, take the chip off and erase all data from it.
    Hi I recently bought a pn7 stuck in demo mode. I took it apart but I dont which chip to erase, there are a few chips that look like flash. Can you point me to the chip you erased?
    • lotas
      • Jan 2016
      • 4648
      • Russia
      #42
      https://www.badcaps.net/forum/showpo...1&postcount=34
      • Ecko5
        • Sep 2022
        • usa
        #43
        Hi, does anyone have a firmware for PK3?
        • 0888572025
          • Dec 2023
          • Viet nam
          #44
          Anyone who has the pl5 file can share it with me?
          • jingleslacks
            • 26
            Anyone have the Xboom RP4 file?
              SMDFlea commented
              Editing a comment
              Off topic.This thread is for the PK5 .Start your own thread and request it.
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • Johndill
            Dell Inspiron 7567 LA-D993P odd charger issue
            by Johndill
            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
            Here are the tested scenarios:
            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
            2. With the laptop off, plug in charger (LED says on) & the front charging...
            11-16-2022, 10:55 PM
