Broken transformer on Carlsbro GRX7
  • OrganiK
    • May 2019
    • 17
    • Spain
    Re: Broken transformer on Carlsbro GRX7
    are those caps in parallel ?
    no they are, there is one for each power rail
    • R_J
      • 9594
      I see two wires had spade connectors on them, I am guessing they connected to the power switch originally, What about the larger secondary wires, were they just floating around in the mixer and not connected to the bridge? too bad the customer played with it first, that's never a good sign. I wonder if this is the original transformer?
      • OrganiK
        • May 2019
        • 17
        • Spain
        Non of the wires where connected, I put the connectors on them wire.
        Yer I also wondered if someone had put a different transformer in it.
        So where did you get the 43V on the secondary before? was it just a guess?
        Edit: Sorry my bad i was just being stupid and could not read the sticker properly it says 43V 3 Amps on it...
        and the caps are doble that, so could well be the right voltage. So do you think i should just try and fit a 2x 43V 150VA Transformer and cross my fingers? lol
        • R_J
          • 9594
          You should try and find out what the voltage should be, if that is not the original transformer, 43vac is meaningless. What is the voltage on the main caps?
          If the 43vac is correct you would have 60 vdc across the + of one capacitor and the - of the other, so about 30 volts across each capacitor to ground.
          This must be the way they are using the transformer.
          The second picture is how it is normally done, so maybe the customer broke the center tap wire completely off the transformer?
          • OrganiK
            • May 2019
            • 17
            • Spain
            The caps are rated at 80VDC so its a bit high for 30 right? but maybe since its old school they like to over engineer stuff a lot, dunno.
            If it was 43Vac on either side it would give about 56Vdc for each cap that makes more sence for the 80VDC on the caps. we also know that its a 150W x2 amp at 2omh so that would need a voltage of about 17Vac = 24.5Vp so that fits better with it being 43Vac total.
            Thanks a lot for you time and patients by the way
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              #26
              + and - 70v for that amp .....https://music-electronics-forum.com/...ad.php?t=19136
              • OrganiK
                • May 2019
                • 17
                • Spain
                #27
                Nice one, so then i would need a transformer that has 2 secondarys with an output of about 50Vac each correct?
                • R_J
                  • 9594
                  You don't need 2 secondaries, you need a center tapped secondary
                    Originally posted by r_j
                    you don't need 2 secondaries, you need a center tapped secondary
                    +1
                    • OrganiK
                      • May 2019
                      • 17
                      • Spain
                      #30
                      I know but can't i make one with a a center tap with a transformer that has 2 identical secondary windings?
                        Yes you can, just wire them up with correct phase.
                        • OrganiK
                          • May 2019
                          • 17
                          • Spain
                          #32
                          Thanks for all the help! much appreciated
                          • hikomalek
                            SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                            by hikomalek
                            Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                            When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                            Transformer:
                            |Info| Primary | Aux | AB | CD|
                            |Ratio|1|25|40|12|
                            |Voltage AC|230V|9.2V|5.8V|19V|
                            |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                            I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                            09-19-2025, 03:30 AM
                          • Wolf1977
                            general question when a mosfet on primary of transformer is burned
                            by Wolf1977
                            hi
                            in a welding machine i had a mosfet and four components wich connect with it burned
                            i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
                            i dont understand whats happen wrong
                            more particular on the schematic q11p01 mosfet q11p02 tranzistor
                            three paralel resistors had burned q11p07 zener shunt q11p08 open
                            when i changed all these shunts q11po7 mosfet and tranzistors
                            maby the transformer has problem on your opinion or something on...
                            08-19-2023, 01:27 PM
                          • peter_wheat
                            Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
                            by peter_wheat
                            Hi All,
                            I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
                            08-28-2025, 02:03 PM
                            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                            by momaka
                            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                            http://www.rmac.kingwin.com/products.../abt_650MM.asp
                            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                            What mostly drew me into buying it is its 2x PCI-E power connectors...
                            03-29-2022, 11:34 PM
                          • mikey5791
                            Is it possible for transformer substitution?
                            by mikey5791
                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                            My questions are
                            1. How do i test to see if the transformer is in good working condition?
                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                            Hope you guys understand what i was asking. My intention is...
                            11-03-2022, 02:11 AM
