Broken transformer on Carlsbro GRX7
  • OrganiK
    • May 2019
    • 17
    • Spain
    Hi all, to summarize I cant work out what the windings ratio, or rather what the VAC output of the transformer is.
    A cliente came in with this GRX7 that is a mixer/power amp, quite old thing. Said it stooped working so he opened it up, saw a loose wire and connected it to where he though it went, but of course that didn't fix.
    So i open it up and found the transformer was not connected up.
    The transformer has 2 primary windings, and 1 secondary winding I live in Spain and we have 240VCA so naturally the to primary coils where connected together, but there wasn't continuity on the primary, so i separated then to find it was only one of them that was an open circuit.
    So to determine the voltage output on the secondary winding i decided to just hook up the mains to only one of the primary windings with the secondary winding disconnected obviously (coz the voltage should be 2x since im using 240 on a single P. Winding), and then mesure the voltage on the secondary, and half of that should be the right voltage, right?? I know that's a bit of an assumption, but any way.
    When i did that it would just blow the fuse, I then put a slightly bigger one but still blows it. so im guessing that primary has had it too. It measures 4 oms with the multi meter
    Any help is much appreciated.
    Thanks in advance.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Broken transformer on Carlsbro GRX7
    What're the odds you got the windings back to front?
    Maybe it has one primary and two secondaries (which would make a lot more sense)?
    What DCR are you measuring across the single "secondary"?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • OrganiK
      • May 2019
      • 17
      • Spain
      Pretty sure it is this way round, since the wires are much thicker on the single winding side and the DCR is 0.6 on that side.
      Good thinking tho, i ques its a single rail power supply
      • R_J
        • 9535
        Post some pictures of what we are dealing with, like the transformer and the rest of the mixer, It should be easy to determine if it has a +/- power supply etc.
        My guess would be a single primary and dual secondaries or at least a center tapped secondary
        • OrganiK
          • May 2019
          • 17
          • Spain
          here are some pictures, were i show both sides of the the transformer, on one side, the one with 2 windings there is a small misterios hole, the board has a 2 terminals, tagged with +V and -V but there is no GND terminal or tag, so I think it is just a single rail and the -V is just the ground.
          Thanks for you quick responses
          • R_J
            • 9535
            The pictures are closeups but don't show the complete unit, Picture 4 shows 2 fuses, why would they put a fuse in the ground line?
            I see part of a large capacitor, is there only one or are there two?
            • OrganiK
              • May 2019
              • 17
              • Spain
              you are right, it is a +/- supply, there are 2 big caps and i just found the GND terminal in in between them!
              But still one of the windings that is on the side where there is 2 is open circuited.
              Also the DCR mesures 0.6 ohms on the single winding side, and 3.6 on the other winding. that makes me think that i have it the right way round. because there the VAC will be lower on the secondary therefor there will be less turns and les DCR. Right?
              And despite all of that, when i connected it up and it blew the fuse, there was nothing connected to the other side of the transformer so there should be only a very small current not enough to blow a 8 amp fuse. but some how i got to find out the VAC out put to order a new one.
              one clue i have is that them big caps are rated at 80V, but that doesn't really help much dose it
                There is sticker on the top of the transformer, can we see straight shots of that label?
                BTW, I see two wires (Blue and Brown) on one side of the transformer :
                https://www.badcaps.net/forum/attach...1&d=1557945236,
                https://www.badcaps.net/forum/attach...5&d=1557945236
                if they stick with wire color codes then Blue will be neutral and Brown will be Hot (Phase).
                On the other side of the transformer I see 4 wires: Brown, brown, orange, orange.
                So I do not see 4 wires for the Hot side in your pictures.
                • OrganiK
                  • May 2019
                  • 17
                  • Spain
                  here are some more photos, so there is a blue and green one on the side with one winding
                  • redwire
                    • 3910
                    I would just pick a winding and inject 6VAC and see what you get out, to figure the out turns ratio on all the windings. A scope helps to confirm phasing.
                    The thinner wiring should be the primary, if it's got a dual 120VAC primary and putting 220V on one of course it would blow the fuse.
                    • R_J
                      • 9535
                      Do you have 7 wires on that transformer? can you ohm out the windindings to match the colors? does one winding have 3 wires by chance?
                      I also see two large capacitors, Usually one is for the positive supply and one is for the negative supply, they will have a common point which is ground. usually the transformer has a center taped secondary where two wires go to the ~ & ~ on the bridge rectifier and the center tap of the winding goes to ground.
                      But who knows with this German built mixer.
                      • OrganiK
                        • May 2019
                        • 17
                        • Spain
                        There seems to be no sing of the center tap on the transformer, you're right about there being a ground terminal in between the 2 caps. Maybe the center tap wire has broken off in side, behind one of the other ones... but I can't see anything behind them
                        Here's a drawing I just done if it helps
                        the orange ones were connected together when I got it.
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          are those caps in parallel ?
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            pic 2 post 5 should clear it up .spades go to bridge .
                            • R_J
                              • 9535
                              I would guess blue and green are the secondary 43 volts, Brown and pink 240vac with the orange and (yellow/red???) connected together. and now the winding between the pink and orange is open. You could supply 120vac to brown and orange to see if you get 43vac for the secondary
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                i would do the 120v also to find secondary voltage and further testing . been there done that .
                                • OrganiK
                                  • May 2019
                                  • 17
                                  • Spain
                                  Even if there is no load on the secondary? would a single primary winding not have a high impedance when there is no current flowing though the secondary?
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    would spike the secondary then blow the fuse most likely .
                                    • OrganiK
                                      • May 2019
                                      • 17
                                      • Spain
                                      yer that's what i thought, Still i recon you right about there should be a center tap on the secondary tho...
                                      Havent got means of getting 120vac... i might be able to borrow an old building transformer, that should do right?.
                                      Still dont quite understand why it would blow the fuse by putting more volts on it if there isn't any load on the secondary
                                      • OrganiK
                                        • May 2019
                                        • 17
                                        • Spain
                                        what from the inrush current? i though that only happend on caps or motors, im really not sure so please correct me if im rong
                                        • Wolf1977
                                          general question when a mosfet on primary of transformer is burned
                                          by Wolf1977
                                          hi
                                          in a welding machine i had a mosfet and four components wich connect with it burned
                                          i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
                                          i dont understand whats happen wrong
                                          more particular on the schematic q11p01 mosfet q11p02 tranzistor
                                          three paralel resistors had burned q11p07 zener shunt q11p08 open
                                          when i changed all these shunts q11po7 mosfet and tranzistors
                                          maby the transformer has problem on your opinion or something on...
                                          08-19-2023, 01:27 PM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • angelos
                                          Technics Transformer question.
                                          by angelos
                                          Hi there,
                                          I have this CD player from a Technics Component unit whose mains transformer is blown. The primary winding is open circuit. This transformer has many secondary windings on its secondary side. This transformer is obviously obsolete.
                                          I need to know if my trick for a alternative transformer will work. Please check the attachment for explanation.
                                          I want to use three separate transformers to be equivalent like the original transformer.
                                          The only thing a bit dodgy is the connection of the 9.6V and 12V outputs of which there is a interconnection between the two windings....
                                          09-14-2022, 02:14 AM
