Help troubleshoot Harman Kardon AVR 1710 Amber light
  • joystik
    • Jun 2016
    • 20
    • Colombia
    Hello folks.
    I have this HK AVR 1710 with amber light not powering up. Found corrosion on hdmi MCU board, cleaned as best as I could. Half of the front buttons didnt respond, including power button. I could do a processor reset with surround mode button, so that worked.
    I powered it up a few times like this and sound and other functions seemed to work well. Still couldnt power on or off using buttons. So I downloaded the service manual from electrotanya (search avr 1710) and found the pins for the front buttons on the MCU. There was no signal reaching those pins and after 2 days I found 2 gaps on the copper traces which i fixed. Now the signal reaches the pins, however, there is still no response. And now, It wont reset.
    I would really appreciate any input as to how to proceed as I have no experience in these digital receivers.
    Thanks.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Help troubleshoot Harman Kardon AVR 1710 Amber light
    You should start cleaning the board, with an ultrasonic cleaner.
    • joystik
      • Jun 2016
      • 20
      • Colombia
      Hi. I dont own an ultrasonic, so I washed it with soap and toothbrush, rinsed with 99% Isopropyl and heated in reflow oven at 105C for 30 min.
      The MCU is a STM32F205. Is there a way to tell if it is booting o working correctly?
      • R_J
        • Jun 2012
        • 9569
        If you found 2 bad traces I suspect there will be more, and due to double sided board, feedthru's might be corroded.
        • joystik
          • Jun 2016
          • 20
          • Colombia
          Whats really troubling my mind is that those 2 gaps were on the same trace and under the green overlay. I had to uncover the copper every few mm to find them. How would that happen? Electrolysis?
          • PowellSkier
            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
            by PowellSkier
            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
            06-17-2024, 11:43 AM
          • funky2x
            Harman kardon onyx studio 7 Smd code
            by funky2x
            Cant find what smd code Y0DVA.
            sitting in Harman kardon onyx studio 7. Appreciate any help.
            05-29-2025, 03:44 PM
          • PowellSkier
            Cement resistor swap in Harman Kardon AVR
            by PowellSkier
            Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
            06-04-2024, 06:41 PM
          • falafinasul
            Harman Kardon AVR 3700 Fonte queimada
            by falafinasul
            Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
            I made a new Diagnostic and verified that the input source is shorted.
            Someone help
            02-24-2023, 05:51 PM
          • BlackScreen_22
            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
            by BlackScreen_22
            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
            I had no problems connecting mosfets and capacitors,...
            08-27-2024, 12:46 PM
