Technika 206 DAB radio NO AUDIO
  • notallbad
    • Oct 2012
    • 1190
    Before Dab is crap rants, I quite agree but would like to try and repair if possible.
    The radio all worked fine however DAB function was never really used due to lack of reception.
    The radio was left in standby (running on Mains supply) over night out in the workshop, couple of days later and the audio has stopped working.
    It all appears to be working, i.e tunes into stations (signal strength bars indicate this), vol +/- control, menu functions etc...
    When switching betwen DAB and FM there is a pop/crackle (not really sure how to explain it) come through the speakers and the LED display dies and comes back to life.
    I have checked the headphone jack hoping the connections had shorted with corrosion but no such luck! No audio through the headphone jack either.
    Also powered it up from a DC power supply with no change.
    Unfortunately there is no Aux in jack to try.
    I am somewhat suspecting the fault to lie with the Radioscape RS220 (RF tuner and DSP plug-in module).
    Photos to follow with component identification.
  • notallbad
    • Oct 2012
    • 1190
    Re: Technika 206 DAB radio NO AUDIO
    Also set the Alarm function to Beep but no sound when the alarm was supposed to go off! It can be set to Fm / DAB or Beep on Alarm, no sound from any function.
    Attempted a factory reset, power up from mains whilst holding in the 'Select' button and still no change.
    • notallbad
      • Oct 2012
      • 1190
      Receives the Date / Time stamp signal too!
      • notallbad
        • Oct 2012
        • 1190
        Re-capped the KSC caps, the 4 bigger main ones on the power distribution/amp board.
        • notallbad
          • Oct 2012
          • 1190
          Casing shell
          • notallbad
            • Oct 2012
            • 1190
            Headphone pcb
            • notallbad
              • Oct 2012
              • 1190
              Tuner / DSP board - Radioscape RS220
              • notallbad
                • Oct 2012
                • 1190
                Power / Amp board
                • notallbad
                  • Oct 2012
                  • 1190
                  Key pcb
                  • notallbad
                    • Oct 2012
                    • 1190
                    Mains supply in / transformer / speakers
                    • notallbad
                      • Oct 2012
                      • 1190
                      Power / Amp board
                      component side :
                      TA8227PG - low freq power amp
                      HEF4013BP - Dual D-type flip flop
                      solder side :
                      LM324 - low power quad op amp
                      PCM1742KE - 24-bit 192khz audio digital to analog converter
                      HEF4093BT - Quad 2 input NAND schmitt trigger
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        So you did a full recap on the amp board and the issue persists?
                        If so, I'd start at the TA8227PG amp chip and work backwards. That is, first determine if the amp IC is getting power on its Vcc pin (pins 1 and 12, looks like).
                        If that checks out, disconnect the two inputs on the amp IC, which most likely will be wired through some input coupling caps. Then feed an audio signal (again through some series coupling caps) into pins 6 and 7. If there is no audio, the amp IC is probably bad. If you do get audio, the issue is somewhere before that then - in which case, start tracing backwards from the signal input pins to see what chip they go to.
                        • notallbad
                          • Oct 2012
                          • 1190
                          OK thanks.
                          Voltages on the TA8227PG
                          pin 1 vcc2 = STBY 0.5v - ON 12v
                          pin 12 vcc1 = STBY 13v - ON 13v
                          • notallbad
                            • Oct 2012
                            • 1190
                            Where would I inject the audio output from this mp3 player via the headphone left, right and gnd wires?
                            Do I need to connect the headphone gnd wire to the gnd pin 4 Pre gnd on the TA8227?
                            Traced back TA8226 pins 6 & 7 to pins 1 & 7 of LM324 Quad amp.
                            TA8227 pin 6 traces back to R25 33k res, then a 2.2uF 50v elec cap, across a jumper link where it T's off to R107 1K res and Lm324 Pin 1.
                            Would breaking this jumper wire after LM324 Pin 1 and the R107 res be ok for either the left or right headphone wire?
                            • notallbad
                              • Oct 2012
                              • 1190
                              Typo above on Post #14, should read 'Traced back TA8227', NOT TA8226!
                              Yep, that done it!
                              Audio coming through the TA8227 on both channels/outputs ok.
                              • notallbad
                                • Oct 2012
                                • 1190
                                The TA8227 inputs are fed from LM324 quad op amp which is powered by a KA7805 Volt Reg.
                                KA7805 volt reg :
                                Input - 13v
                                Output - 4.95v
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  PCM1742KE - Audio digital to analog converter
                                  Pin 5 - digital vss - 3.2v
                                  Pin 6 - analog vss - 4.95v
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    How do I inject audio through the LM324?
                                    Same as before with the mp3 player headphone 'fly' lead via the traces on the PCM1742KE, pin 9 AGnd, pin 7 VoutL and pin 8 VoutR??? Of course isolating pins 7 & 8 of the PCM1742KE first!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      You got it.
                                      Isolate the audio outputs of the PCM1742KE and connect your input to the LM324.
                                      That said, I wonder why they have the LM324 for and not connect the PCM1742 chip directly to the amp IC. Buffering, I suppose? Perhaps we can get a closeup shot of the LM324 circuit to see how it is connected. I suspect there may also be some kind of "tone equalizing" done with it too.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Hope this close up photo shows enough detail.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
                                        • i_am_patch
                                          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                          by i_am_patch
                                          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                          04-30-2024, 08:20 PM
