Polk Audio PSW111 Subwoofer - no power
  • Bterrier
    • Apr 2018
    • 72
    So I picked up a polk audio psw111 from the thrift store for $10. Doesn't power on, knew this going in but figured it was worth the $10 to see if I could get it working.
    The fuse at the iec socket is blown....I have a few on order. (1.6a 250v)
    Im wondering if replacing the fuse would resolve this or if there is an underlying issue. I'm assuming the fuse will blow again when I replace it because I don't feel it would blow for no reason.
    Looking for insight and what steps to take to troubleshoot this issue.
    TIY
  • dmill89
    • Dec 2011
    • 2534
    Re: Polk Audio PSW111 Subwoofer - no power
    Originally posted by Bterrier
    So I picked up a polk audio psw111 from the thrift store for $10. Doesn’t power on, knew this going in but figured it was worth the $10 to see if I could get it working.
    Im wondering if replacing the fuse would resolve this or if there is an underlying issue. I’m assuming the fuse will blow again when I replace it because I don’t feel it would blow for no reason.
    TIY
    There is a good chance the driver transistors are blown, those polk sub amps are notoriously underbuilt (especially older ones). There may also be conductive glue if it is older (brown glue that carbonizes and turns dark-brown/black and becomes conductive with time/heat). Polk also likes to use really cheap caps (crap like Jun-Fu, Fuhjyyu, etc.) in these amps that can fail as well. I'd start by testing the driver transistors (with a multi-meter/ transistor tester or just pull them and see if the fuse still blows) and also check the bias resistors and caps. If there is conductive (dark brown/black) glue scrape it off the board. If it is new enough to have a switching power supply that may have failed components as well.
    Dayton (parts express house brand) and others sell replacement sub amps if all else fails, but at $50+ it probably isn't worth it (you can often find decent working subs on ebay for that price).
    After owning a Polk powered sub (don't remember the exact model but it would have been circa 2005-2006 and failed in 2012) that blew its amp and an seeing what a steaming pile of crap the amp (cheap caps, conductive glue, undersized heat-sinks, etc.) was in a ~$300 sub (the Sony I replaced it with which was half the price has a much better built amp) I'll never buy another Polk sub/powered speaker (I could understand that build quality in a <$100 off-brand sub but not in something positioned as a "premium" product). Their un-powered speakers may be fine but I don't the trust the powered stuff.
    • Brucetafer
      • Jun 2018
      • 133
      I fixed mine after replacing all the smaller caps, theres a TON of write ups on the PSW 110+, the amps are junk.. I ended up rebuilding the entire amplifier with quality components..
      • Bterrier
        • Apr 2018
        • 72
        Thanks, any chance you have a link to one of the write-ups or guides to repairing these? I'm very new t troubleshhooting and reparing this kind of things.
        The fuses came today. Tried one out just to check, and it blows immediately
        • Bterrier
          • Apr 2018
          • 72
          Thanks, I'll definitely take a look at the transistors. This isn't too old, manufactured in 07 I believe. No brown glue, but they appear to be using some type of yellow foam or silicone maybe. There is one area where this yellow glue/silicone looks to have been heated up and turned brown. I'll upload a photo later.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            That stuff turns brittle, conductive AND corrosive, so don't discount dissolved PCB traces or component legs either.
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • kotel studios
              Lantec PULSE 386 subwoofer - no audio output
              by kotel studios
              Hi
              I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
              After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
              The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
              11-29-2025, 04:15 AM
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • Babbar
              by Babbar
              04-12-2024, 01:12 AM
            • Delicieuxz
              I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
              by Delicieuxz
              I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
              Here's an audio clip of the sound coming from my speakers:
              https://vocaroo.com/16HaryHwTx78
              I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
              11-15-2023, 09:50 PM
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
