Another Yamaha
  • No1baggiesfan
    • Jan 2019
    • 45
    • England
    Another Yamaha
    My Yamaha RX-V671 has an illness
    I think we had a power surge/outage a couple of days ago as my PS4 informed me that I hadn't turned it off properly, it's usually left in rest mode to charge the pads, anyway, amp turned itself off when my wife turned it on, and then again, so I tried, same thing, I reset the amp, checked all speaker cables, then powered it back on, it worked fine for about 45 mins then switched off again.
    Diagnostic mode gives the error: PS: PRT 135 H
    I also see a fluctuating value in p1-2 diagnostic: PS 160/129 which suggests a high volt error somewhere ?
    No C405 on this amp lol
    I have the service manual, but wiring diagrams have never been my strong point :/
  • No1baggiesfan
    • Jan 2019
    • 45
    • England
    Re: Another Yamaha
    Nobody ?
    • redwire
      • 3912
      Re: Another Yamaha
      Why would someone repeat the work others have done, reading the schematics, interpreting 160/129 etc.
      You've cross-posted the same repair to at least two other forums:
      https://www.eevblog.com/forum/repair/yamaha-amp-woes/
      http://repairalmostanything.com/thre...-yamaha?page=1
      Perhaps you should finish work with those forums.
      • No1baggiesfan
        • Jan 2019
        • 45
        • England
        Re: Another Yamaha
        Because I received no replies on one forum and only a couple on the other, is it wrong to ask nowadays ?
        • CapLeaker
          Leaking Member
          • 8332
          Re: Another Yamaha
          It's never wrong to ask a question, but if you want to get folks more interested in your case, maybe you should update this thread on what you know, or have figured out in the mean time. You also didn't attach the service manual nor pictures, so I am sure not too many folks are going to spend their time on it like this.
          I've seen your posts on the other forums as well and figured your were well on the way.
          If it would be me, I'd check and monitor that voltage source. Since it goes high after some time being turned on and is not stable wandering around, I'd say it is heat related. It could be something stupid like a cold solder joint.
          • No1baggiesfan
            • Jan 2019
            • 45
            • England
            Re: Another Yamaha
            Apologies, I forgot about the service manual.
            Not easy to look at on an iPhone lol.
            I haven't spent a lot of time on it so far, mainly checking for dry joints, and checking caps that have been mentioned in previous posts.
            • kndm17
              • Jan 2019
              • 14
              • United Arab Emirates
              Re: Another Yamaha RXV671
              Hi, Please Do check all the Transistor Amplifier. each pair consists of PNP and NPN Transistor. Make sure that they are okay. try to compare the measurement. then after that try to hang all QPins one by one. after that go to Protection Circuit and check if there is no suspicious component.
              If all the components are okay you can proceed to check the Main Power Supply.
              Thanks.
              • redrooster
                • May 2011
                • 114
                Thanks.
                What do you mean by "Hang all Qpins one by one? I've been repairing gear for years if I don't know what you are talking about how is this guy going to figure it out?
                HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
                • CapLeaker
                  Leaking Member
                  • 8332
                  Re: Another Yamaha
                  Well, I'd start measuring all voltage rails and see what gives. There are 2 options. A: a regulator failed, or B: something is dragging a voltage rail down.
                  • redrooster
                    • May 2011
                    • 114
                    Re: Another Yamaha
                    Have you checked for burnt or discolored resistors? Give the amplifier a good clean with a new paintbrush and vacuum cleaner, dirt and fluff can become moist and conductive causing the protection to cut in. If you don't know how to test transistors or whatever just say so.
                    • No1baggiesfan
                      • Jan 2019
                      • 45
                      • England
                      Re: Another Yamaha
                      From what I can see there are no burnt, discoloured or swollen components, the inside is tbh quite clean.
                      If I've read the manual correctly, then Ic89 is a required voltage test, but I can't see in the manual what they are supposed to be.
                      Video 7 board has 7.2v off both terminals
                      Video 2 board has 5.4v from all 4 pins to video 3 board
                      I'm getting 46v and 21v from transformer, but that is in circuit
                      None of the "transistor amplifier" test as shorted, all gave the same ohm reading
                      Qpins ?
                      • redrooster
                        • May 2011
                        • 114
                        Re: Another Yamaha
                        From my experience with Yamaha amplifiers, nothing really goes wrong with them unless they are dirty or get overheated? Do an ohms test on your speakers at the terminals, what are they reading and do they match?
                        • R_J
                          • 9594
                          Re: Another Yamaha
                          Measuring the resistance across the speaker terminals will check open because the relay contacts will be open. If you want to check the resistance of the outputs, check between ground and the center of the dual 0.22Ω emitter resistors.
                          Do a diode check of the 4 diodes in D1040 bridge rectifier.
                          • redrooster
                            • May 2011
                            • 114
                            Re: Another Yamaha
                            You have misread my post. I'm talking about measuring the speaker terminals! One of those might be causing the protection to cut in.
                            • R_J
                              • 9594
                              Re: Another Yamaha
                              It is unlikely a shorted speaker would cause this, the protection activates when it sees a high DC offset voltage on the outputs.
                              From the error that is given it is likely one of the low voltages that is at fault
                              • No1baggiesfan
                                • Jan 2019
                                • 45
                                • England
                                Re: Another Yamaha
                                It's definitely not a shorted speaker, there is nothing connected to the amp to cause a short and this amp has speaker short protection anyway, I know lol, I saw the 'check spkr' message a few years back when I first installed it
                                • R_J
                                  • 9594
                                  Re: Another Yamaha
                                  A error P1-2 PS: 160/129 would indicate a fault with the lower voltages like 5v 3.3v etc.
                                  Check your + & -12 volt supplies, also check the voltages on Q1067 collector and Q1068 emitter. If they are ok, the fault could be with one of the 5v or 3.3v voltages, there are more than one of each
                                  Check that you have a good 5.5v coming from the ac-dc converter, this is the standby voltage that is allways on and is the source for the 3.3m voltage to the digital board
                                  • CapLeaker
                                    Leaking Member
                                    • 8332
                                    Re: Another Yamaha
                                    That's what I am thinking too. The fault code indicates a low voltage rail problem.
                                    • No1baggiesfan
                                      • Jan 2019
                                      • 45
                                      • England
                                      Re: Another Yamaha
                                      12v on CB101 is 15.4v
                                      Q1067 is 0.6v middle/top 0.05v middle/bottom
                                      Q1068 is 1v Middle/top 1.6v Middle/bottom
                                      • R_J
                                        • 9594
                                        Re: Another Yamaha
                                        CB101 is the AC input to the D1041 bridge rectifier from the transformer, You would be better off checking the DC voltages on the regulator ic outputs, IC101 should have +12 volts, IC102 should have -12 volts.
                                        learn what the pinouts are on transistors, Q1067/Q1068 need to be checked when the amp is turned on. If it is in standby you will not have any voltages at all.
                                        There are about 20 different voltage sources in this amp, you need to be able to identify them and then check there voltages
                                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                          what is wrong with your PC in just seconds. It saves you time and money.
                                          Our new and improved design...
                                          11-01-2024, 06:29 AM
                                        • Sinnyone
                                          Yamaha RX-V3900 dim display and turns off
                                          by Sinnyone
                                          This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
                                          I have searched through the forums and have not found anything about my problem. So,...
                                          08-30-2023, 08:35 AM
                                        • nzphil
                                          Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                                          by nzphil
                                          I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                                          04-11-2021, 05:58 PM
                                        • sanalelevenstar
                                          Yamaha RX-V485 Wn9711 Update
                                          by sanalelevenstar
                                          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                          12-04-2024, 04:32 AM
                                        • sanalelevenstar
                                          Yamaha RX-V485 receiver. After encountering a "version error"
                                          by sanalelevenstar
                                          I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                          After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                          I managed to find the service...
                                          09-10-2025, 01:54 AM
