Logitech X-230 PC subwoofer powerless
  • steves7839
    • Nov 2014
    • 200
    Hi all; I searched the Audio Forum for this model and found one thread from 2009. Apparently the OP was able to get the electronics out of the subwoofer cabinet to upgrade components. My question is; how?
    The symptom is the power LED no longer lights. The DC power supply is inside the subwoofer, but I cannot see how to remove the PCB or open up the sub without destroying the cabinet.
    The speaker set was designed for a PC. It worked fine until I left it unused for a year or so. One speaker contains the volume/on-off knob. The two speakers are powered by the subwoofer thru a DB-9 plug. I've flexed the cables and connections but got no sign of power or sound.
  • mmartell
    • Oct 2013
    • 3189
    Re: Logitech X-230 PC subwoofer powerless
    Through the removed woofer maybe ?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Remove the screws on the metal plate at the back of the woofer and you may have to pry the plate-amp a bit to loosen and remove it. The PSU and amplifier is on the plate.
      • steves7839
        • Nov 2014
        • 200
        Originally posted by Andrew F. Ali
        ... you may have to pry the plate-amp a bit to loosen and remove it. The PSU and amplifier is on the plate.
        I can only get one corner of the circuit box out of the case. Some of its' wiring must be secured inside.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          How easy is it to remove the speaker? Most likely it's the speaker wire not long enough. Don't tug on it too hard, though.
          • R_J
            • 9552
            Here is the video, its a pain to remove the grill so try not to bend it out of shape https://www.youtube.com/watch?v=aLoh4jRSgfU
            • steves7839
              • Nov 2014
              • 200
              Great, thanks for that video link. That should get me moving forward!
              • steves7839
                • Nov 2014
                • 200
                The issue appears to be with the 110VAC-14.4VDC transformer. It has no electrical continuity through the AC side. To be continued.
                  May be you can upload good clear pictures for us to look at.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    You seemed to have found the issue with the Subwoofer. Replace the transformer and your system would work again. If you cant get a transformer with a 14.4 V output a a5V output would work. It would be a 2.5A to 3A transformer.
                    • steves7839
                      • Nov 2014
                      • 200
                      I bought a 1A 120VAC-7.5+7.5VAC transformer. I only bought one NTE5801 diode for rectification. With this transformer it appears I will need 4 diodes to create a bridge. I also bought a ECG4926 15.3V zener for protection and a 100uf 100V non-polarized capacitor for filtering. The speaker pcb uses 14.4VDC at 1A.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        I think you would need at least a 4700uF 50V Electrolytic capacitor as a filter as that 100uf 100V non-polarized capacitor CANNOT be used as a filter. Instead of 4-diodes to build a bridge why not simply get a bridge rectifier instead?
                          How did you come up with 100uF 100V NP for filter Cap?
                          You need to show the pictures of the inside the unit.
                          BTW, something is not right about the label on top of that transformer, it shows O/P 14.4 VDC 1.0A, you better show us more pictures of what we are dealing with.
                          https://www.badcaps.net/forum/attach...8&d=1545332571
                          • steves7839
                            • Nov 2014
                            • 200
                            Originally posted by budm
                            something is not right about the label on top of that transformer, it shows O/P 14.4 VDC 1.0A]
                            True. The only way I can explain the transformer labelling is perhaps the transformer has an internal rectifier or two, which would convert AC to a pulsed "always positive" wave.
                            My power supply design is purely speculation; I will go with a larger nonpolarized cap as recommended above.
                            • steves7839
                              • Nov 2014
                              • 200
                              After taking a closer look at the PCB, I see a diode bridge next to the fuse, and a 4700uF 25V cap nearby. Looks like the transformer provides AC (despite the stamped output legend) and the PCB takes care of rectification.
                              I plan to reassemble it on that assumption and see what happens.
                              • steves7839
                                • Nov 2014
                                • 200
                                I supplied AC to the primary of my new 7.5+7.5V output transformer. The secondary was left open. Measured output on the secondary leads was <2VAC. The transformer also got quite hot.
                                The primary reads `70 ohms. The secondary reads nearly continuity between one tap (red wire) and center tap? (green wire). The two red taps read 6 MegOhms resistance between them. This makes me question the internal connection of the secondary.
                                Is an open-circuit test even valid or should I load the secondary?
                                  Looking at the picture, did you have the Green wire center tap connected to the red wire? Is that what you did?
                                  "The two red taps read 6 MegOhms resistance between them." The winding has gone open circuit.
                                  • steves7839
                                    • Nov 2014
                                    • 200
                                    Correct and confirmed. I marked it defective and exchanged it for a new one. With the new xfmr, the primary taps measure 70 ohms, as I would expect. The secondary taps each measure 9 ohms to the center tap, and 18 ohms across. That's more like it. Unloaded, each tap delivers 10.5 VAC for 21 VAC total.
                                    I connected one secondary winding and the center tap to the PCB and hooked up all the speakers. Voila!
                                    Last decision: Should I run all 21 VAC to the PCB by connecting both secondary windings? I suspect the original transformer, labelled OV 14.4V, provided close to 20VAC as well when working. The power supply filter cap on the PCB is 4700uF 50V so I think it could take it.
                                      So the original transformer only has two wires for the secondary side?
                                      • steves7839
                                        • Nov 2014
                                        • 200
                                        Yes. I am upgrading from a nominal 14.4V AC output transformer to a nominal 15V if I connect the entire secondary. As I noted above, the measured OV under load is 10.5V AC between the center tap and either secondary, so 21V AC total.
                                          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-12-2024, 01:58 PM
                                        • rustinjust
                                          Please help, subwoofer connected to tv, read description below
                                          by rustinjust
                                          I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there a way of...
                                          10-28-2023, 07:09 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Delicieuxz
                                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                          by Delicieuxz
                                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                          Here's an audio clip of the sound coming from my speakers:
                                          https://vocaroo.com/16HaryHwTx78
                                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                          11-15-2023, 09:50 PM
