Luxman L-215 repair no or bad audio on one channel / LED mod
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8179
    Got this old Luxman L-215 in for repair. Complaint: One channel not working and a bad zener diode.
    Took it home and sure enough, almost no audio on one channel, even so both LED's are on in the amp.
    The repair:
    1: LED mod. The Zener diode D112 was bad and left a black spot where it was installed. C133 was bad too and R153 was hot. I modified the circuit a little bit. Removed D112 altogether. Snipped R153 on the output side and added another 500 Ohm 2W resistor (all I had in the junk box) in series for combined 800 Ohms in total. Replaced C133 with a 100uF 50V capacitor out of a junk board. Took out the old lamp. Soldered a NSI45020 led driver to the pin on the function switch PCB, replaced the old bulb with a blue LED. Works great!
    2: The audio repair: Both of the LEDs in the amp section were on, so the amp had to work. Basically I found tons of bad solder joints on the main and tone control board, dirty switches and variable pots.
    Another one saved from the bin!
  • dicky96
    American Audio VLP1500 Distorting on one channel
    by dicky96
    Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
    Protection and Clip LED are off
    There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
    I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
    The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
    07-13-2022, 05:25 AM
  • akarta
    Onkyo TX-SR702 no audio after channel repair
    by akarta
    Really strange one. Got this amp with digital noise coming from all channels. BAD cap on 12V rail and burned via on -12V rail causing -7V and +7V rails missing, audio noise and "SP CONFIG" message (thinking that MIC is plugged in then it is NOT, but before I replaced cap and fixed rails I have accidently left it ON with output transistors for rear channels hanging in air (NOT HEATSINK ). One channel blew. After further inspection found a LOT of caps out of range on DSP and Processor boards. Replaced every single one that did not pass my ESR test(almost all).Got receiver back together...
    05-02-2022, 08:54 AM
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
