Denon 4308CI NO AUDIO
  • ngen33r
    • Sep 2016
    • 24
    I picked up a Denon 4308CI cheap and the unit powers on fine but I have no audio output. I tore the unit down and found on the audio unit board a bad cap and a blown transistor. C507 100uF 50V and TR501 KTA1268. The KTA1268 is not available so I need to find something equivalent.
    https://cdn.badcaps-static.com/pdfs/...fffd426395.pdf
    This one is close but not exact.
    Any recomendations?
    Re: Denon 4308CI NO AUDIO
    992 is only rated at 50mA Ic, 1268 is rated at 100mA.
    • ngen33r
      • Sep 2016
      • 24
      I cannot find an exact match at digikey or mouser.
      I can go 1/2 the rated voltage
      or
      Higher voltage and less gain
      Or I can try my chances on eBay transistors which are probably fake.
      • tibimakai
        • Jan 2012
        • 3680
        You could also contact Digikey, and they may suggest something.
        • ngen33r
          • Sep 2016
          • 24
          Never thought to do that. Thank You
          • ngen33r
            • Sep 2016
            • 24
            They recommended these:
            https://www.digikey.com/product-deta...X795A-ND/92573
            Parts ordered let's see what happens. I am replacing all of the caps in that section as one of them ruptured, which most likely killed the transistor with noise the other parts seem to test ok.
            • ngen33r
              • Sep 2016
              • 24
              I recapped that section of the board and replaced the PNP with
              The transistor blew again when powered on so another problem exists.
              • ngen33r
                • Sep 2016
                • 24
                Any ideas on this one because these look like the muting circuits they shouldn't have excessive current flowing through them.
                • R_J
                  • 9558
                  Hard to tell without the service manual. The partial schematic you posted does'nt even show C507.
                  • R_J
                    • 9558
                    I found a schematic, I take it the transistor shorted? if you remove it, what voltage do you get on TR501 collector (C503) it should be around -7 volts. also check the base voltage (d511 anode)
                    What was wrong with C507? You should check the voltage on each side of C507, you should have -12v on the negative and possibly +5v on the positive lead.
                    (Page169)
                    • ngen33r
                      • Sep 2016
                      • 24
                      C507 was blistered and leaking, could be an un-related problem. I checked the voltage rails and everything seems to be good there.
                      I will test the things you listed tomorrow.
                      • ngen33r
                        • Sep 2016
                        • 24
                        More problems found:
                        B - 34V
                        C - 10V
                        E - 61V
                        I unplugged CW155 & CW068
                        B - 100mV
                        C - -3.88V
                        E - 475mV
                        More checking shows both transistors (TR630 TR631) on the 5V supply are shorted and I have a blown audio output. IC301 is also fried. My guess is the blown output is the cause. I am not sure that I can find a replacement for the outputs. IC301 might also be impossible to source. I am not sure if I trust eBay parts but that may be my only option. I have the service manual but it is too large to post.
                        • ngen33r
                          • Sep 2016
                          • 24
                          Must have been a big boom.
                          • ngen33r
                            • Sep 2016
                            • 24
                            Trace Repaired:
                            • Häiriö
                              • Sep 2018
                              • Finland
                              Have you checked the main amplifier transistors? Usually when they short they take some smaller transistors also.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                http://pacificsemi.com/search.php
                                SAP15N
                                • ngen33r
                                  • Sep 2016
                                  • 24
                                  Mains were blown. I also found a bad diode.
                                  https://www.digikey.com/product-deta...03P-ND/3661836
                                  • samson7point1@yahoo.com
                                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                    by samson7point1@yahoo.com
                                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                    The player processes the audio signal using two different reference frequencies. The "R"...
                                    04-30-2024, 11:22 AM
                                  • ajvpb
                                    Denon 3313CI Distorted Audio FL+FR
                                    by ajvpb
                                    Hobbyist repairman here so I've reached the end of my troubleshooting abilities. The audio out of the FL+FR speakers is very distorted and almost unintelligible. BUT! That only applies to digital audio; Analog plays through just fine. The distortion carries to headphones if those are plugged in with audio from a digital source. All other speaker channels play fine regardless of digital or analog.
                                    Previous experience with similar distorted audio has been bad resistors on the amp output - Could bad smd resistors on the hdmi board cause the same problem? My understanding...
                                    02-22-2023, 05:21 PM
                                  • dicky96
                                    Denon AVR-X500 No audio output
                                    by dicky96
                                    Hi guys, I have this AVR-X500. It has no audio output but if I select some input (DVD) and connect an audio signal to the RCA DVD inputs, I hear a relay click and sometimes there is a slight crackling on the speakers.
                                    I only have 2x 8ohm speakers attached to Left and Right front.
                                    If I plug headphones in, the crackling noise stops but I get no audio on the headphones.
                                    I checked the voltages marked on the connectors on the Preamp PCB (12V, 5V etc) and they are all present. There is also plus/minus 56V on the bridge rectifier on the main amplifier PCB...
                                    02-22-2022, 08:36 AM
                                  • Cornito
                                    Denon AVR-2700H audio stops while receiver still works
                                    by Cornito
                                    Hello team,
                                    I've got a new issue with a Denon Avr-2700H.
                                    After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                    Receiver still work and display video with error message on display.
                                    Seems to me that is the main output relay.
                                    I'm looking for the service manual that I can't find for the moment.
                                    Does somebody have it?
                                    Regards...
                                    08-03-2025, 06:10 AM
                                  • oshimapt
                                    marantz sr6012 no sound
                                    by oshimapt
                                    hello guys,
                                    first of all i'm not a qualified repair guy, i am a diy guy and as years pass by i have some experience on repairing eletronics, and i'm hoping someone can share their experience.
                                    i have a marantz sr6012, some times it turns on and works normal, but after a while the sound cuts off or it starts getting distorted and then cuts off.
                                    when this happens there is no audio no matter the source used, and the OSD shows unknow audio signal from the source.
                                    i was reading very carefuly the service manual and it is all pointing for...
                                    10-17-2024, 09:49 AM
