Nikko TRM-600 vintage stereo amplifier
  • suiramix
    • Mar 2011
    • 131
    Hi ,
    Got this little amplif and tried to find the schematics ...no luck, just TRM-500 model. According to other forums, there is no big difference between them! So basically the this Nikko amplif will power for 1 sec and the primary breaker will cut the power. Did a reset of this breaker same result ! Open the wood top cover and everything is amazing clean , no visible damage or burned components...and lots of wires (kind of scared) !!!
    What will be the right approach in this case ... should I disconnect the power supply and measure the voltage?
    Re: Nikko TRM-600 vintage stereo amplifier
    Start by providing good clear pictures of the inside.
    What components did you test so far for shorted circuit?
    • suiramix
      • Mar 2011
      • 131
      Hi Martin,
      I will post some photos... for now, the amplif was plug-in without any speakers and flip the main switch. The red light turn on for one sec and after that is dead! Not been able to measure anything...see attached similar TRM-500 schematics.
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        probably shorted output transistors or rectifier diodes ..
          Originally posted by suiramix
          Hi Martin,
          So you cannot test the components such as Transistors in the power amplifier sections, rectifiers in the power supply section?
          • suiramix
            • Mar 2011
            • 131
            Yes guys...just 2 screws holding the power transistors , removed both and ...are dead ! What it will be the best replacement of 2SD188 and 2SA627 ?
            Thanks again!
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              Mj21194g
              mj21193g
              • suiramix
                • Mar 2011
                • 131
                Hi Pete,
                Thanks for your help...this is the first vintage amplif I ever opened and kind of overwhelmed (even is not that complicated). However, I did notice another transistor marked NEC C959 with some overheat marks , removed and is fried.
                What will be the best equivalent for this 2SC959 and possible 2SA606 ?
                • petehall347
                  • Jan 2015
                  • 4440
                  • United Kingdom
                  2n3440
                  • suiramix
                    • Mar 2011
                    • 131
                    Hi again,
                    I have the output transistors available are ready to replace the old one. I assume after that a biasing is need it. Did a lot of reading about DC voltage on the speaker output bindings (close to 0V) but still not clear about idle current through the output transistors ...can someone explain the process and what is the optimal value for this model. Thanks again!
                      R659/660 are for DC Offset adjustment.
                      R675/676 are for bias adjustment.
                      Make sure not to connect speakers to the output because there is no protection circuit (I.E speaker protection relay) to detect large DC offset, so check the DC offset the out put to see how close it is to 0V, if it shows <100mV or so that will be good sign, if it shows in Volts then try to use the DC offset pot to see if you can set it to 0V (10 ~20mV reading is fine)
                      So you will set the offset Voltage to be as close to 0V as possible after the set is warm up for about 1/2 hour.
                      the typical bias current for the output Transistors is about 30mA, so you will set your meter to milliVolt range then measure the DCV across either R691 or R693 (for one of the channel) then adjust the bias pot to show 14mV (0.47 Ohms x 30mA = 14.1mV), do the same on the other channel on R692 or R694.
                      I would suggest you to use probes with some kind of clips to attach to the resistor legs so you will have less chance of slipped probes and short out the circuit.
                      If I were you I would put 75 Watt incandescent lamp in series with LINE (HOT/ PHASE) feeding the unit so if it lights up brightly and stay that way then you know you still have problem with the circuits, the lamp should come on bright for seconds during the main filte caps being charged and then the lamp should dim down a lot after that.. you will also notice that the lamp may change brightness when you make the bias adjustment. I usually do the adjustment with lamp in place and do it again without the lamp.
                      • suiramix
                        • Mar 2011
                        • 131
                        Hi Martin,
                        Thanks again for your detailed tutorial! The DC offset went smooth, no too much adjustment, but for bias of power transistors one of the trimpot is newer (R675) than the other (R676) and I can not adjust it too much.
                        However I did connect the speakers and Right channel is super clean and amazing sound ...the Left channel with distortions. Also on this LH channel I did change Q660 and Q653 with 2N5415 and 2N3440. For now I will replace the trimpot (both channels) and report the findings.
                        • suiramix
                          • Mar 2011
                          • 131
                          Finally, both channels are loud and clean...one emitter resistor (R694, 0.47R) was acting strange...replaced with similar for now and all the biasing adjustments are done nicely.
                          Last question: as per schematic diagram, there is no indication for the power of this resistor , it looks like 2-3W and is not wire-wound or ceramic. What will be best option for this case? Thanks again!
                            3 ~ 5 Watts non-inductive ceramic resistor type.
                            You can use something like this but 0.47 Ohms:
                            http://handsontec.com/index.php/prod...ment-resistor/
                            • DrDos
                              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                              by DrDos
                              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                              08-08-2025, 03:16 AM
                            • Sik_6ty_Sixx
                              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                              by Sik_6ty_Sixx
                              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                              02-18-2025, 05:06 AM
                            • labello
                              California Electronics pro-8800a digital amplifier stereo
                              by labello
                              Hi guys my friend gives to me this thing, it works but the selector on of music is broken , I tried to do some research on Internet to change it but I didn't find anything. I hope that someone can help me to find it thanks all for the reply
                              05-04-2024, 09:41 AM
                            • goodpsusearch
                              Technics SU-Z45 vintage amplifier repair
                              by goodpsusearch
                              Got this for free, previous owner said when he connected speakers on amplifier he heard very loud cracking noises and immediately disconnected it to avoid damaging speakers and he was going to throw it away.
                              When I opened the case I didn't notice anything visibly burn/bulging.
                              Then I connected some suicidal speakers and turned on amp. Nothing.
                              Then played with volume control and heard noises that could be due to dry/dirty potentiometer.
                              Then connected audio input and retried. Left channel was working but the right channel was dead and...
                              01-15-2022, 01:35 PM
                            • MrCommunistGen
                              Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                              by MrCommunistGen
                              My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                              I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                              07-12-2021, 05:11 PM
