Polk Audio PSW 110 subwoofer
  • batch85
    • Jun 2018
    • 5
    • Philippines
    #41
    Re: Polk Audio PSW 110 subwoofer
    Thanks again sir frankusb, and thanks also sir budm for that detailed photo of the filter cap and the SMPS IC.God bless both of you.
    • frankusb
      • Apr 2015
      • 111
      Well I've been using this subwoofer since the summer and it recently developed a hum. I decided to take budm's advice and replace the remaining capacitors. After doing that, the subwoofer no longer powers on. The LED blinks once a second or so. I've checked multiple times that the replacements were installed correctly observing polarity and that the voltage/capacitance matched the replacement parts. I am inclined to swap back to the previous parts and then install and test incrementally.
      Any better ideas on how to approach this?
      • R_J
        • Jun 2012
        • 9594
        This is a double sided board and you likely pulled the feedthru's out when you removed the capacitors, have a close look at the leads on the original capacitors, if their is a piece of the circuit board remaining on the lead thats your problem.
        Post good clear pictures of the boards so we can have a look.
        • frankusb
          • Apr 2015
          • 111
          Thank you, I did damage a trace during removal. I found it on the first capacitor I pulled and had to make a small bridge out of a copper wire.
          The subwoofer is powered on without any hum.
          • ben2talk
            • Apr 2019
            • Thailand
            #45
            OK, my turn now... ordered a 5-bag of 47uF 64V Panasonics (stated 10,000 hours lifespan... let's see). Sadly my eyes even with glasses gave me a headache (I left college in 1986 - I wasn't too bad then, but things got smaller and tighter since then!) so I'll be popping out to a local mobile phone repair guy to do my soldering.
            • Kadro Correa
              • Dec 2020
              • Brasil
              #46
              q14 and q15 are burst I can't identify them in my circuit
              Can someone help me
              • Kadro Correa
                • Dec 2020
                • Brasil
                #47
                Can someone help me
                I know they are the same of Q20 and Q21, but i dont know the order
                • fabio_rm
                  • Mar 2022
                  • Italia
                  #48
                  They are the power mosfet on the right of the pcb, near the speaker output
                  • fabio_rm
                    • Mar 2022
                    • Italia
                    #49
                    I have part of amplifier schematic, lack the schematic of oscillator/comparator little pcb mounted vertical and seems nowhereto by found. Anyway on the schematic there are not voltage reference, i think voltages on the transformer output are too low , nobody know something about what need to be these voltages after the rectifier diodes over filter suplpy capacitors?
                    • fabio_rm
                      • Mar 2022
                      • Italia
                      #50
                      I try again. Nobody can measure the voltages on the secondary of the transformer after the rectifier diodes, when the sub is running and in the ON state?
                      • bfarnam
                        uhhmmmm
                        • Jun 2019
                        • US
                        #51
                        Thread Revival -
                        @Kadro Correa Q14 is IRF9Z24 and Q15 is IRFZ14 and they drive the SPK + wire from Vcd+ and Vcd-.
                        @fabio_rm the voltages on the secondary after the full wave rectifier should be the same as the mains minus any voltage drop from the full wave bridge rectifiers. This circuit is ALWAYS LIVE as there is no on/off switch.
                        If you voltage is low, I would suggest looking at the primary voltage ripple cap, C24, 150uF 400v. This is likely underrated and this is the same for the PSW110, PSW111, and PSW225. Also check continuity on D15, D16, D19 and D20 (full wave bridge). If one of these is open the voltage will be low.
                        When replacing C38/C39 it is important to keep the rated ripple current at 90mA or higher. A higher rated cap will prolong it's life.
                        Brett
                        If you really want to find me, you should already know how. Otherwise just send me a PM.... however their may be a delay as I am a REALLY busy person.
                        BTW, I love the Mitsubishi DLP's and have three working units and chassis parts from another.
                        • samson7point1@yahoo.com
                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                          by samson7point1@yahoo.com
                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                          The player processes the audio signal using two different reference frequencies. The "R"...
                          04-30-2024, 11:22 AM
                        • Delicieuxz
                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                          by Delicieuxz
                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                          Here's an audio clip of the sound coming from my speakers:
                          https://vocaroo.com/16HaryHwTx78
                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                          11-15-2023, 09:50 PM
                        • exceptional
                          Help monitor audio gxw-15 subwoofer
                          by exceptional
                          Have a problem with one of my gxw-15 subwoofers. When pluging in power socket it shows power is ok (red LED), but when trying to turn it on it turns iff immediately (can hear relay clicking sound). Cause i have working second subwoofer i tried replacing several boards. So for now i can say power board is causing this problem. There are no visible damaged element on it. I wrote to Monitor audio and they sent me all schematics. What i have found is defective capacitor C535(short circuit), but after changing it ...same behavior.
                          Measured output FETs, diodes. Seems everything is fine......
                          10-17-2023, 03:51 PM
                        • old_marantz
                          Help monitor audio rxw-12 subwoofer
                          by old_marantz
                          I have a monitor audio subwoofer rxw12 that is clicking. Avsforms has a thread on this and I saw someone posted schematics here for it. Since I’m a newbie and no one here in salt lake will work on it, I guess I’m elected.
                          Supposedly the issue is “ smd type and located on the soldering side of the amplifier board”. Can you experts help me identify which one it might be? And what to order? How difficult to put these in? I’ve replaced caps before but just eyeballing what these resisters might be on the board, they look pretty small.
                          I saw some...
                          08-20-2023, 05:46 PM
                        • i_am_patch
                          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                          by i_am_patch
                          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                          04-30-2024, 08:20 PM
