MTX 801D Amplifier Cap Help
  • willne1
    • Mar 2009
    • 13
    Hello All...this is my first post here and I'm a newbie at cap replacement so please be a little patient with me. This amp was working and now it will not power on. I removed the cover and noticed some of the caps are bulging and the two bigger ones in the picture have flaking skins and tops (no bulging) but other than that they look o.k. with a visual inspection by me. I would like to ask you guys what caps to use to replace the smaller caps and should I replace the two big ones? I can't seem to find an exact replacement for the six smaller ones, they are Nichicon ZA stamped on the side 470uf63v. The big ones have no name as far as I can see but they are stamped 50v 2200uf and the numbers 28c03l are on them.
    I'm having trouble getting the image to upload I'll try again in a few.
    TIA
    willne1
  • Logistics
    • Apr 2007
    • 721
    Re: MTX 801D Amplifier Cap Help
    Just upload the image to imageshack.com and then link it.
    There are a slew of good replacement capacitors. Personally, I use Panasonic FM or FC from Digi-Key whenever possible, but they are not the only good cap. First thing you'll need to do is figure out the diameter of said caps. I'll just go with FM's and FC's for the moment since I can't find information about Nichicon ZA's.
    In FC's you can find 470uF 63V in 12.5mm diameter and 30mm height or 16mm diameter and 20mm height. The 2200uF 50V can be had in a 18mm diameter and 35.5mm height. Couldn't get these in FM's.
    What are the values on the smaller caps?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • willne1
      • Mar 2009
      • 13
      Thanks....here's the link....http://i196.photobucket.com/albums/aa15/willne1/328.jpg
      • willne1
        • Mar 2009
        • 13
        Do you think I should replace the two big ones?
        • PlainBill
          • Feb 2009
          • 7034
          Dude!!!
          Those are Nichicon VZ's, not ZA!! Nichicon HE or PW series should be a step up, but perhaps you should let the capacitor experts weigh in.
          My inexpert opinion is the two large caps got unpleasantly hot. Definitely replace them too. Call it your own little stimulus effort - when the Dow hits 20,000 in 2012 you can claim you did your part.
          Now those four very large caps way in back. Is the third from the left bulging, or is that the cord behind it?
          PlainBill
          • Toasty
            • Jul 2007
            • 4171
            <<----- Hands PB his glasses...
            It's the cord.
            @willne1-
            Some overhead pics or a slightly higher angle would be better, plz.
            veritas odium parit
            • Wizard
              • Mar 2008
              • 2296
              that secondary caps, replace them all.
              Cheers, Wizard
              • willne1
                • Mar 2009
                • 13
                This is the only other pic I have. If needed I can take more tomorrow. That is a cord in the back those caps look fine to me. Thanks to all for helping, what do i get to replace the two big ones that are shedding? http://i196.photobucket.com/albums/aa15/willne1/330.jpg
                • PlainBill
                  • Feb 2009
                  • 7034
                  DamnifIknow. I tried using my crystal ball, but it's in for repairs (the caps are fine).
                  Try to get pictures that show both sides of the cap. Again, Value, Voltage, and Series.
                  PlainBill
                  • linuxguru
                    • Apr 2005
                    • 1564
                    Large Nichicon VZs from that era were prone to leaking from the bottom bung - definitely replace them with Nichicon Muse (FG, KG, KZ, ...), Panasonic FC or Rubycon ZA/ZL. There are various other choices in the price/performance spectrum - starting with Black Gates and other snake-oil at the top of the price band.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i would not waste audiophool grade parts on a noisemaker amp.
                      i use a lot of fc in the smps section in these when i service them.better than what comes stock.
                      the guys that use them are half deaf anyhow!its fine if it goes boom boom.
                      • willne1
                        • Mar 2009
                        • 13
                        I took some more pics today, hopefully I can get an idea on what to get to replace the two that are pealing.
                        http://i196.photobucket.com/albums/a...1/P1000426.jpg
                        http://i196.photobucket.com/albums/a...1/P1000423.jpg
                        http://i196.photobucket.com/albums/a...1/P1000422.jpg
                        • PlainBill
                          • Feb 2009
                          • 7034
                          It appears the two big ones are United Chemi-Con SMH series. They are available from Digikey (565-2664-ND) for $2.58 each. I'll let someone else identify a better cap.
                          PlainBill
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            looks like those are on the +12 input.
                            suckers got hot!maybe reversed polarity?
                            take a shot at the bottom of the pcb centered on those 2 caps.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I just realized this is for a car. Make sure the replacement caps are the same dimensions as the original!
                              Oh, bells peal. Apples, bananas, oranges (and caps) peel.
                              PlainBill
                              • Toasty
                                • Jul 2007
                                • 4171
                                Please measure the clearance for replacement caps. Going by the ELNA series LP5's (now LA5) in the background, you should have clearance >35mm high.
                                Panasonic FC series for the VZ's (12.5x20mm, 640mA ripple) - 470uF/63v - 12.5x30mm, 2090mA ripple - EEUFC1J471L
                                http://search.digikey.com/scripts/Dk...name=P10351-ND
                                Nippon Chemi-con SMH (22x25mm, 1.91A ripple) replace with same SMH series but step up to 3900uF/50v - 22x35mm - ESMH500VSN392MP35S - 40% more ripple current @2.65A
                                {{Shown as xxx35T by Digi - Manuf site catalog shows xxx35S? Dimensions are the same.}}
                                http://search.digikey.com/scripts/Dk...me=565-2666-ND
                                veritas odium parit
                                • willne1
                                  • Mar 2009
                                  • 13
                                  Here's a shot of the bottom. Once again thanks to everyone for the help.
                                  http://i196.photobucket.com/albums/a...1/P1000429.jpg
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    Another thought.
                                    Mind the removal procedures listed on this site:
                                    https://www.badcaps.net/pages.php?vid=32
                                    Those big SMH's apparently (from the photo, ty) have their other lead soldered through to the top side. If you don't apply enough heat to melt the solder on the top side, you could end up ripping the traces off the board underneath them. Do not force them. Rock them gently, towards the other connection, as in step 2. Do not force them. (repeated for effect).
                                    veritas odium parit
                                    • willne1
                                      • Mar 2009
                                      • 13
                                      O.K. Toasty...thanks for the link. How would you guys recommend I hold this board while I'm removing the caps? It has a funny shape since the regulators are sticking out on the sides and the controls on the one end (see the pic).
                                      http://i196.photobucket.com/albums/a...1/P1000431.jpg
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Ummm... Carefully??
                                        Upside down on several towels or foam material to cushion. You can probably stand it up on them on the power connection end if necessary.
                                        veritas odium parit
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
                                        • Francesc V.
                                          Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                                          by Francesc V.
                                          Hi:
                                          I've realized that one of the channels of this amplifier has no proper sound.
                                          This is the signal at the speakers output.
                                          As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                                          Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                                          07-15-2025, 01:33 AM
