MTX 801D Amplifier Cap Help
  • willne1
    • Mar 2009
    • 13
    Re: MTX 801D Amplifier Cap Help
    Thanks for all the help Toasty, I'm going to order the caps you recommended if everything works out o.k.during the desoldering process (wish me luck).
    • Toasty
      • Jul 2007
      • 4171
      You did check those clearances, yes?
      veritas odium parit
      • willne1
        • Mar 2009
        • 13
        Now that you mention it...the big caps in the background are 32mm tall so the 35mm caps might be too tall, any other ideas?
        • Toasty
          • Jul 2007
          • 4171
          Just check to see what your clearances are. I'm sure the big ones weren't smack up against the case... or were they? Jeeze, we're only talking 1/8" here. Measure it.
          Does this board slide into a grove in the case/housing?
          veritas odium parit
          • willne1
            • Mar 2009
            • 13
            Well Toasty, I looked at it again today and the cover comes down to within 2mm from touching, 35mm would definitely be too tall.
            • Toasty
              • Jul 2007
              • 4171
              #26
              Bah! I'll bet they'd fit. A little work with the shoe horn.
              Anyway, try this one: (22x30mm, 3300uF, 50v)
              http://search.digikey.com/scripts/Dk...me=565-2665-ND
              Less capacitance than the first replacement I suggested, but still more than what's there and slightly higher ripple filtering.
              veritas odium parit
              • willne1
                • Mar 2009
                • 13
                #27
                Once again Toasty...Thanks, it looks like that's the one.
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  Any word? Is it fixed?
                  veritas odium parit
                  • willne1
                    • Mar 2009
                    • 13
                    #29
                    Sorry for taking so long to follow up Toasty. I didn't have any luck with the amp because I couldn't get the old caps off the board. Man they're really on there good.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      What wattage iron are you using?
                      I'd recommend something over 50 watts maybe 80 w or better. You have a HUGE heat sink with those copper traces and it does suck all the heat up quickly.
                      LMK
                      Toast
                      veritas odium parit
                      • willne1
                        • Mar 2009
                        • 13
                        #31
                        Hako 936-12 and I also have a Weller 7200 gun I think it's 75 watts. I didn't try the gun. I thought that might ruin the board.
                        • Toasty
                          • Jul 2007
                          • 4171
                          #32
                          I don't think the Hakko is strong enough. The gun should do a good job, but you have to be quick! Don't overheat the board or you will damage and lift the foil.
                          Use the procedure from the main page on badcaps.net. Down the left hand side there are some How-To's. Use the " heat one leg and rock it to one side then do the other the same way" procedure. Make sure that you can feel the cap come loose before you rock it sideways. It means the solder top to bottom has liquefied.
                          In your picture of the board bottom, the cap leads with the little square around them are the most treacherous. You have to apply enough heat to get the solder loose on the top side of the board, but not so much as to cause the trace to lift. Those are the ones that are most likely to get ripped up if you don't use enough heat. Heat the lead, not the solder. A little flux or extra solder will get it going quickly.
                          Also, heat the board from the top with a hair dryer while you're desoldering the caps. It will give you a bit more time and take less heat to get them out. Sounds like a bit of juggling, but it can be done.
                          Good Luck!
                          Toast
                          veritas odium parit
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            @willne1
                            Any luck or progress?
                            veritas odium parit
                            • MrCommunistGen
                              Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                              by MrCommunistGen
                              My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                              I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                              07-12-2021, 05:11 PM
                            • jinu_j
                              How to test Subwoofer Amplifier with only a multimeter
                              by jinu_j
                              Hi Folks
                              Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                              Problem
                              I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                              Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                              Any advice would be appreciated...
                              08-29-2024, 02:05 AM
                            • UserXP
                              Mackie CR4 amplifier no sound
                              by UserXP
                              Hi, people.
                              I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                              Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                              10-17-2020, 05:06 PM
                            • Coert van Dorsten
                              Sansui Integrated Amplifier replacement volume control troubles
                              by Coert van Dorsten
                              Hi all you clever electronmic gooroos!
                              I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
                              10-15-2025, 02:54 PM
                            • mikey5791
                              Help on car amplifier only one channel works
                              by mikey5791
                              Hi all forum members,
                              Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                              My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                              08-06-2025, 10:36 PM
