Pioneer VSX824/529 burnt out resistor R453
  • JerryG1765
    • Apr 2018
    Hi Guys
    Can someone help me to identify value of this resistor R453 located on Amp PCB.
    Many thanks
    Re: Pioneer VSX824/529 burnt out resistor R453
    You will get a lot more help by uploading good clear pictures of what we are dealing with.
    • petehall347
      • Jan 2015
      • 4426
      manual not all there
      • R_J
        • Jun 2012
        • 9535
        You would need to locate the manual for the VSX-1024-K, or you could locate the same resistor in one of the other channels to find the value.
        • DjKrish
          • Oct 2012
          • 354
          • SG
          A picture of the board up and down would help. Theres identical resistors in every channels.
          • CG2
            LED uplighter dimmer burnt resistor
            by CG2
            I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
            02-14-2024, 09:23 AM
          • trickartt
            Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
            by trickartt
            Hello Badcaps!
            I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
            This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
            05-04-2024, 12:07 PM
          • sparcktikus
            Ersa Rds 80 soldering station burnt resistor
            by sparcktikus
            Hi
            I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
            I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
            The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
            Many thanks...
            04-04-2023, 04:29 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
