Need help identifying component
  • lyvemyche
    • Apr 2018
    • 5
    Good afternoon everyone and Happy Easter!
    I have the head unit (radio) out of my mustang because it works fine for a while, then occasionally it just dies. It acts as if there is a short on the board, I can tap on the chassis and it will come back on for and work perfectly again... I have traced the problem back to this component here. if it isn't working, I can tap directly on this and it will come back on. Can someone help me to identify what this is so that I can then order a replacement?
    Thank you in advance for your help.
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Need help identifying component
    sup might mean suppressor .. have you checked the solder ?
    • lyvemyche
      • Apr 2018
      • 5
      I think Ill try to resolder it and see if that helps. I believe it is a suppressor. I also posted in another forum and that has been the best guess...
      • R_J
        • 9551
        You could post the make and model of the radio, or the year of mustang it is from, there might be a schematic around
          • 31063
          it's a spark-gap device, sometimes called a GDT (gas discharge tube)
          the colours indicate the trigger voltage.
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            what use is one of those in car audio ?
            • CapLeaker
              Leaking Member
              • 8193
              here is a run in I had with a KIA radio.
              https://www.badcaps.net/forum/showthread.php?t=60291
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                tvs..suppression diode .. spark gap is something else . or so i heard
                • CapLeaker
                  Leaking Member
                  • 8193
                  it would be nice to see the whole board.
                  difference between gas discharge and a TVS is, that the first one is a crowbar and the second one a clamp. Both will protect and as long as the TVS is low in capacitance, there is no ill effect either. I use mostly TVS (do a lot with RF and phone lines), they either clamp or short, depending on the event.
                    The device is not needed for the circuit to function, its job is for protection, it will stop the circuit if it is shorted out. You can just lift one legs off the board and check its resistance, it should show infinite resistance.
                    It sounds like you have bad connection.
                    • CapLeaker
                      Leaking Member
                      • 8193
                      yeah, it is between the antenna and the RF input to GND. All it does (if it is shorted) send the antenna to GND on which you'll have a deaf VHF receiver.
                      Problem is that the description of the op is kinda vague.
                        • 31063
                        if it's across the antenna then it's to protect the radio in a thunderstorm.
                        if it does fail, it will just stop you recieving any stations though, so i think you have other issues.
                        that said, it looks blackened inside - they should be crystal clear so you can see the electrodes.
                        about the difference between a spark-gap and a semiconductor like a tvs or a mov.
                        semiconductors switch off at the same point they trip,
                        a spark-gap latches till the energy is gone, but they have a lower capacitance - good for tuned circuits.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4963
                          • New Zealand
                          Running from a 12v battery might sound really simple, but the power supply in a car can be very noisy, lots of voltage spikes etc, especially when the engine is starting or when it is shut off, EMI from ignition system when running, etc.
                          Also lots of potential for ESD events since the car is insulated by the tires and high voltages can build up (Ever get a static shock when stepping out of your car?)
                          Check the attached document: Protection of automotive electronics from electrical hazards, guidelines for design and component selection.
                          -David VanHorn
                          • lyvemyche
                            • Apr 2018
                            • 5
                            Thanks for all of your input guys, I really do appreciate it. From what I have learned in the last few days... Its a gas discharge supressor that protects the radio from static discharge. I understand that normally this suppressor is an open circuit and it protects by absorbing, or shorting any static charge to ground, which is the right suppressor lead as shown in the photo. I have also been told that if this has protected the head enough times, the gap may be damaged and is shorting out, perhaps a loose speck of metal in the gap randomly shorts it and it works again... I have ordered another one and I am now waiting on it to arrive. What has been happening is that radio will work fine, then one day, you'll get in and it just wont power up again. The clock will randomly flash, that's about it. With the radio opened up I plugged it all back in and turned on the key, still nothing. If I lightly tap directly on the suppressor, it comes right back on again, everytime and works perfectly until a couple of cycles of the key then its out again.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4963
                              • New Zealand
                              It may also be a bad solder joint or other faulty component near the suppressor.
                              -David VanHorn
                              • TheKROCZ
                                Need help identifying the missing cap on the back of an i5 3570
                                by TheKROCZ
                                Hey guys. I have an i5 3570 with a capacitor knocked off from the back of the cpu. I got it with a semi faulty mobo that I got for really cheap. The rest of the cpu is in a bad shape as well but its mainly cosmetic damages. I did try to run it and my test bench booted but the system never posted. It just got warm. My test bench did not crash either. It just kept running.
                                From the looks of it, I think the cpu can be revived by soldering on a new capacitor. However, no matter where I look online, I am unable to find any details about the capacitor or anything about the layout of those...
                                06-17-2022, 11:15 AM
                                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                by sam_sam_sam
                                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                I am comparing them to a brand new one that I installed
                                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                I going to let it run for several days before I remount back on the wall next to the...
                                09-05-2024, 06:48 PM
                                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-12-2024, 02:30 PM
                                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 08:10 PM
