KIA car radio TVS diode blown, need help identifying it
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    Someone gave me his original KIA car radio for repair. I did find that the 5.5V Super Cap was leaking and a TVS diode shorted. The problem is that I have no idea what value that diode is. It is a glass style TVS with one yellow or gold band in the middle (D101 on the bottom right of the picture). It goes between the antenna input of the tuner module to GND. What value should this diode be?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: KIA car radio TVS diode blown, need help identifying it
    I would try a NTE 519 Diode (depending on which section of circuitry it resides.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8331
      I suppose I could just chuck just about any lower voltage bi-directional TVS diode in there. But I'd still like to figure this original diode out. I haven't seen any TVS with a single yellow or golden band yet and I can't find it in any chart either.
        What ever you out in probably should be low capacitance since it is in the RF section.
        • redwire
          • Dec 2010
          • 3912
          Are you sure it has shorted? In-circuit you will get low Z reading from the antenna to GND from the tuning inductors. The TVS is for static electricity buildup on the antenna rod. I have not seen any look that big.
          On second thought, that looks more like a gas tube surge protector:
          http://www.diytrade.com/china/pd/128...rge_tubes.html
            The designator is D101 and the printed symbol on the PCB also shown as TVS diode.
            He should lift one leg up and test it again.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I think any TVS you may have at hand or easy access to should work. Before replacing though test a known good one and compare the results with the one you are working with.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8331
                Yes, I agree... it does have to be a low capacitance diode, because of it being in the RF section. Yes, the diode is shorted out of circuit, it's done for. I doubt the voltage rating is going to do much as long it's under 30V or so. The capacitance of the diode is more important. The bi- directional TVS is just a protection of the antenna port of the tuner there isn't any voltage there. Hence the reason, that one could just about any low voltage, low capacitance diode in there without any ill effects.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8331
                  I've ordered a couple of TVS diodes. Hard to find a low capacitance TVS through hole style. SMD No problem.
                    I remember in the early day when they started using MOSFET in the RF Front end of the tuner, they had lots of failure due to lack of protection.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8331
                      Well... I am getting my share to repair ham TRX's from our club. Some transmit from one radio into the other one, the other gets somehow 120V through the antenna port TWICE! The usual Kenwood, Yaesu, Icom and PSU problems, failing IF amps, PLL unlock, blown up this, broken that. However I have to come across a glass style TVS with one yellow color band yet.
                      • redwire
                        • Dec 2010
                        • 3912
                        The KIA radio pcb is SMT and this lone TVS is big through-hole. I find it a weird part too.
                        I usually see low capacitance diodes for antenna protection on Rx and gas-discharge tubes for lightning protection on Tx gear.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8331
                          I hear ya. Same here.
                          • iyas132
                            Corsair RM 750 blown schottky diode near ES1DF
                            by iyas132
                            Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                            Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                            My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                            Can anyone help me identify the component...
                            12-30-2024, 01:34 AM
                          • shelby5041
                            clock radio / radio lifespan?
                            by shelby5041
                            hi
                            ive got a modern digital clock radio approx 15yrs old
                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                            it uses very little power just a few watts i would imagine that may have something...
                            09-14-2024, 03:30 AM
                          • MrSparkle91
                            Help with a blown Diode (Lenovo 15ith6h)
                            by MrSparkle91
                            I have recently gone to clean my laptop and noticed a bad Diode that's gone poof. I have also located it on the schematic also.
                            Whilst I'm good at repairing stuff in general, I would like some kind insight into what I'm working with here and the Diode I would need.
                            I have checked the whole laptop and suffer no issues usability wise, which is why I was shocked to find this, but am I right in thinking this is power voltage related?
                            Thanks in advance....
                            08-01-2025, 10:30 AM
                          • repair-it
                            Need help identifying this (double?) diode
                            by repair-it
                            I tried to locate online without any success but maybe someone else might have better luck. If it is a double diode - it's done - based on the reading I got in diode mode....
                            07-14-2025, 10:25 AM
                          • magneh
                            Help identifying diode - ST Microelectronics marking EUV C730
                            by magneh
                            Hello all!
                            could someone help identifying this ST diode?
                            Marking EUV C730
                            Photo attached,
                            Thanks in advance!...
                            01-22-2025, 09:08 AM
