Onkyo P306RS Preamp Left Channel of Phono stage Popping and Hissing.
  • Territup
    • May 2016
    • 5
    • usa
    Hello I have a problem with an Onkyo P306RS Preamplifier Everything works perfect on it accept when the input is set to phono the Left channel pops and hisses and blows the over protection on my Amp which is an Onkyo M-5030. It is only there when you turn up the volume and when nothing at all is connected to the phono Inputs its still there I connected my turntable and the right channel is fine but the left is just the Distortion seems to not be getting any signal input from the left input.Its got me stumped because it is only when it is on phono I haven't had it long i just didn't have a turntable so I never tried the Phono stage on it . Anyone have an idea where i would check for distortion on just he phono section it sounds like a leaking cap but this Preamp is pretty complex it shows in the service manual the phono section has 2 of the super servo circuits in it which are all in there own orange plastic cases under the Huge Metal Plate which is to just block out external distortion from outside devices etc. The plate weighs about 20 lbs and has a screw securing it to each or the Super Servo Amps like its a heat sink but it isnt the part it screws to are plastic. If anyone has any experience with these preamps it would be greatly appreciated if you could tell me where to start etc. And also i was wondering if an old 5mhz Scope would be good enough to possibly help in troubleshooting the older amps and preamps . All i have at the moment are two 5meg scopes ones a Ilco Model 460 and the other is a Heathkit IO-5205 lol, I'm Showing my age here lol. Any help would be appreciated.
    Thank You!
  • redwire
    • 3910
    Re: Onkyo P306RS Preamp Left Channel of Phono stage Popping and Hissing.
    I could not find a schematic for Onkyo P306RS. I did find Onkyo P3060R and assume it is similar.
    It could be dirty switches or a failed semiconductor, probably not caps.
    It's a DC-coupled preamp and any imbalance would go through to the outputs. If the power amp is also DC coupled, it will trip its protection circuit as the DC offset just propagates through.
    The phono preamplifier left channel needs work, I would measure voltages on the transistors. You can compare to the right channel. Also measure the phono input RCA jacks to see if there is DC offset there. If so, do not damage your phono cartridge if it got say >10V. ESD can damage the input JFET 2SK148 but rare and hard to find that part.
    There is one DC null trimpot and a servo-amp trimpot just for the phono preamp; same for the preamp output amp. If they were out of adjustment, I wouldn't expect popping noise.
    The diyaudio site might have people there who know more.
    • Territup
      • May 2016
      • 5
      • usa
      Thank you Redwire the schematic i found is for the p-3060 too. It has the discharging hissing popping sound from the left channel even without any input on it so it does it without the turntable even connected. You don't hear it unless you start turning up the volume then it will blow the amp protection and the Amp is a Onkyo M-5030. I cant see where the phono section is on the schematic is it the section right under the equalizer section on the schematic? it shows 2 servo amps in it but there are like 6 inside of it all mounted under a huge metal plate each servo amp is in a orange plastic box that the cover is removable. The metal plate screws into each of the plastic covers, it isn't a heatsink it is a shield for external interference is what I have read. Where do you suggest I measure voltage at on it ? Thanks for your help.
      • redwire
        • 3910
        The phono-preamp is called "equalizer amplifier" on the schematic. Higher level signals like Tape, Aux, Tuner etc. go right past it as they don't need an extra amplification stage.
        It looks like the amplifier sections are in black shielded boxes? Around them looks like servo circuitry, in this picture I found.
        I'd take the covers off, to access the phono sections. Parts nearby matching the schematic would tell you if you are in the right section. i.e. twin capacitors C301, C303 are left servo caps. I think the phono modules are nearest the center chassis bar. Or post pictures, that would help.
        The main risks here are static electricity- touch earth ground somewhere before touching the insides.
        And making sure the filter capacitors have discharged for a while before poking around.
        • Territup
          • May 2016
          • 5
          • usa
          Thank You Redwire, The boxes are orange and say servo amp on them. I will take pictures tomorrow and post them mine is a little diff than the photo you posted.
          So I think the whole left circuit board is for the phono section like you said. I thought it was just a part of it not the whole thing lol .It makes more sense now I will post the pics tomorrow. It might just be the switches need cleaning I have to get some deoxit and clean them but when i hook the turntable up I didnt hear any music just the leaking noise and popping. I got to order the cleaner online im in Alaska and no where has any here lol. The switch connects to a ribbon cable like a mechanical ribbon cable that goes to a switch on the main EQ board. Should i clean that also or just the switch contacts I have never seen a setup like it before.
          Thanks for your help again it is really appreciated.!
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • analogicalmind
            Allen & Heath Xone:92 mixer problem - faulty phono channel outputs on one side only
            by analogicalmind
            Wondering if anyone here can help – I have an Allen and Heath Xone:92 silver mixer with one faulty channel – channel 2 is only outputting on one side (right side) when set to a phono input. It works fine with a line input, and all the other channels work perfectly with phono and line inputs. I'm not sure when this happened as I rarely use the faulty channel – it could well have been like this for years! Any thoughts on what might be causing the fault and how it could be repaired? I can do some basic soldering, so I'm hoping I might be able to fix it myself.
            02-17-2022, 12:33 PM
          • mikey5791
            Help on car amplifier only one channel works
            by mikey5791
            Hi all forum members,
            Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
            My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
            08-06-2025, 10:36 PM
