HARMAN KARDAN HS250 Fuse blown
  • srt1
    • Aug 2013
    • 177
    • india
    Hi , i got Haramn Kardan HS250 from My friend , the problem is fuse was blown, i replaced the fuse , now power is ok except amplifier voltage , i am not getting any out put from smps to amp section, any one can help me where i need to check to find the faulty , i attached here service manual.
    Re: HARMAN KARDAN HS250 Fuse blown
    Can you please upload good clear pictures for us to see so we can see what we are dealing with?
    • R_J
      • 9545
      What you attached is the owners manual. start by downloading the service manual and check the parts in the pfc circuit, Q501, R506,507,510,512, then check Q509 & R572
      • srt1
        • Aug 2013
        • 177
        • india
        Sorry, it was my mistake, any way now i just found a trace blown near to big filter capacitor side on high voltage rail, that provide supply voltage to the smd ic after i join with a piece of wire power supply is ok.. But i dont know the exact reason to blow out that trace, i found that the yellow glue got very dark brown when i check its c conducting using multi-meter its shows some slightly conducting
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
        • drscoot
          HP X360 convertible battery blown fuse error, not charging
          by drscoot
          HP Modelnumber: 14-dh0061nb​
          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
          All these 3 batteries are charging...
          12-15-2023, 05:54 AM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • whc14765
          Gigabyte 980TI Windforce - Blown PCIE Fuse
          by whc14765
          Hey,
          I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
          The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
          I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
          1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
          04-08-2022, 06:22 PM
        • NConstantinou
          Lenovo nm-d471 fv1 fuse blown
          by NConstantinou
          I found that fv1 on one side i have 19v and on the other side 0v.
          The fuse is 3a 32v FOR BACKLIGHT.
          I do not have such a tiny fuse.
          Can i replace it with a wire and what size.
          I know i am overpassing fuse but i don't have any other solution.
          02-14-2023, 06:44 AM
