Lenovo nm-d471 fv1 fuse blown
  • NConstantinou
    • May 2017
    • 354
    • Cyprus
    I found that fv1 on one side i have 19v and on the other side 0v.
    The fuse is 3a 32v FOR BACKLIGHT.
    I do not have such a tiny fuse.
    Can i replace it with a wire and what size.
    I know i am overpassing fuse but i don't have any other solution.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo nm-d471 fv1 fuse blown
    Putting a jumper for fuse is not recommended but will work if there is no other problem. Newer lenovo boards fuse are very tiny-You can go for a smilar rating fuse although in bigger size and solder one pad of the new fuse to pcb one side and connect a jumper wire from other pad to fuse. That way you will still have the protection of fuse.
    • NConstantinou
      • May 2017
      • 354
      • Cyprus
      Thanks mcplslg123,
      i will take your suggestion, it makes sense.
      thanks again
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • Acnologia
        Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
        by Acnologia
        Here is a pretty crazy one.
        Step 1.
        Laptop was brought to me as dead not working. Removed everything , cleared everything.
        Step 2.
        Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
        Step 3.
        Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
        Step 4.
        Lets ,dive into the board. I see the edp cable on the...
        05-07-2025, 07:16 AM
