LG bh9530tw home theater no power
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi folks, im in need of service manual for this model. Any kind soul able to upload the service manual for me? The model is LG bh9530tw
    Few of the smd components burned at the bottom
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: LG home theater no power
    SMPS model is EAX63689124
    Can anyone pleaseeeeeeeee help me get the service manual for this model?
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Like it stated in the smps, the same power supply is used in various models such as BH7xxx, BH8xxx, BH9xxx and DH7xxx. Does anyone has any service manuals for any of the said models?
      • Khron
        • Sep 2006
        • 1350
        • Finland
        I can't be 100% sure from the first photo, but it kinda looks like most of the components between the PWM chip and the MOSFET gate are toast.
        http://omapalvelin.homedns.org/tesla...fets-large.gif
        T2 = Q912
        T3 = Q913
        D2 = D913, with R948 added in series with it
        R17 = R907, in parallel with the series'd D913/R948
        ZD905 added to limit the max voltage going to the MOSFET gate; FB903 in series with the gate, to prevent high-frequency interference from affecting the gate.
        Odds are good the PWM chip is gone as well. Can you still read the markings on it?
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • DjKrish
          • Oct 2012
          • 354
          • SG
          T2 = Q912
          T3 = Q913
          Didnt realise that LG service manuals are really hard to find. Sighs. Thank god manage to get the manual for DH series that uses the same smps. Now i have identified all the components
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Ok time for updates. Have changed all the faulty components. Power is up. Theres standby light on the home theater BUT i measured the voltages on the power board, the voltages on all the pins seems higher than rated as i checked using MM on DC mode. Now thats weird. Check screenshot
            Upon measuring using MM on DC mode, these are the voltages im getting
            3.8VA im getting 9.3VA
            6VA im getting 13.7VA
            14VA im getting 31.8VA
              I did not look at the schematics yet but I wonder if those Voltages may not be ref. to the circuit common GND.
              • DjKrish
                • Oct 2012
                • 354
                • SG
                Hi budm, heres the service manual that has the exact same smps. Pls check and tell me what u think.
                • mmartell
                  • Oct 2013
                  • 3189
                  Some of the joints on T901 look suspect at least from the photo you provided.
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    That was when i first took it out. Its all soldered already. Now the board is all good. Just wanted to verify the mismatch of voltages. Dont wanna end up blosing things again. Thats why i dont dare operate the unit yet. For now, i know the power light is there. So there is standby present.
                    • redwire
                      • 3910
                      Optocoupler PC903 (transistor) may be open circuit, it connected to the blown parts and controls voltage regulation.
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        All 3 Optocouplers has been replaced
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          Im sorry i dont get u budm.
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            Remove as much of that yellow glue as possible because it becomes conductive when aged.
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              All removed. I couldn't turn on the unit. Its stuck at standby. Then later on after a few minutes upon checking all voltages, the standby light vanished as well. Checked for voltages again, noticed all voltages from the psu is reducing drastically with load. If i power on without load, the voltages are stable.
                              • Rain0989
                                • Jul 2018
                                • 27
                                Hey
                                I have the same sound system with same problem --> NO POWER
                                Can you tell me what you have replaced?
                                Perefctly with the voltages and Amperes from the SMDs that you have changed.
                                best regards
                                • Rain0989
                                  • Jul 2018
                                  • 27
                                  Push
                                  • Rain0989
                                    • Jul 2018
                                    • 27
                                    Push
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      Nope still no luck as i couldn't fix the power.
                                      • R_J
                                        • 9555
                                        Maybe if you posted the service manual with smps schematic (post#8) others could help.
