Yamaha RX-V677, Distorted sound at higher volume
  • srt1
    • Aug 2013
    • 177
    • india
    hi,
    i got Yamaha last week, its have sound distortion problem, in lower volume sound is fine but when i am increasing the volume sound getting distorted especially when lower beats coming , i appreciate your support on this i, I already check all rail voltages in amplifier its all in within limit as per SM, but when i check at AMP-LMT , getting 2.6 VOLT but i am not sure its normal or not ,i appreciate all of yours support on this.
  • srt1
    • Aug 2013
    • 177
    • india
    Re: Yamaha RX-V677, Distorted sound at higher volume
    In my understand it is audio clipping somewhere , i am suscpecting its in pre amp stage or in electronic volume ic ,,any one had same experience ?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      When you say increasing the volume what exactly do you mean?? Louder than normal level at perhaps loud as a party volume level??
        • 31011
        test it on headphones.
        if it's only with speakers then it could be failing smoothing caps not providing the current.
        • srt1
          • Aug 2013
          • 177
          • india
          Its not lounder than normal level .its in normal level only that mena if i cramk the volume to -45db its starting distortion especially in bass tones
          • srt1
            • Aug 2013
            • 177
            • india
            Today i checked power suplly of ic173 its in within limit as per SM that is +7volt and -7 volt.then i again checked pre amp stage power rails i found ther a negative rails missing ( before i couldnt find or i miss it)i colundnot get -56 volt i found that transistor q1068 ( in schematic) gone bad.. what i did that now i just by passed collector to emitor by using a 2.2ohm resisitor , i got sound without any distortion ..so the peoblem is bad q1068 but i dont know why its blown.when i checked with multimeter I found short between base and collector ..
              No sign of over heating? How about the Voltage at the Emitter and the Collector of the transistor used for the + supply for the pre-amp?
              So circuits take +/-61V input and drops them down to +/-56V.
              • srt1
                • Aug 2013
                • 177
                • india
                No over heating , the voltages at emitter and collector of transistor is around 56 volt , for pre amp stage reducing the voltage from +/-61 rails
                i attached here amp schematic
                  You should also test Q1071 (2N5401)off the board to make sure it is good.
                  • srt1
                    • Aug 2013
                    • 177
                    • india
                    I CHECKED That transistor , it is not blown , and i replaced A1837 now amplifier is ok no distortion at all........
                    • maleksa
                      Yamaha MOX8 boot freeze and distorted sound
                      by maleksa
                      My Yamaha MOX8 synthesizer recently developed two issues.
                      Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                      Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                      11-07-2024, 03:28 AM
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • jjne
                      Yamaha RX V675 sound issues
                      by jjne
                      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                      At first I thought it was either a speaker relay or the DSP, but I don't think...
                      06-24-2025, 07:01 AM
                    • jorpec
                      Loewe opta R125 distorted sound at high volume
                      by jorpec
                      Hi
                      I'm restoring this vintage radio, that had a very weak sound output, after replacing the electrolytic capacitors the sound volume improved but when the volume reach the middle of the knob starts to distort, its like the speaker overdrive and saturates, but only at lower frequencies even with the tone knob at minimum on bass frequencies. i have tried with other speakers but is the same.
                      Any idea what causes this ?
                      Below the schematic
                      Thanks...
                      03-02-2022, 11:51 AM
                    • Rupsenkind
                      Yamaha RX-A1030 working, no sound output
                      by Rupsenkind
                      Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
                      Just to recap:
                      No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
                      07-10-2022, 03:15 AM
