Denon AVR 390 Volume not increasing
  • srt1
    • Aug 2013
    • 177
    • india
    I got denon AVR 390.its volume showing always min and no sound also .i cannot increase the volume anybody facing same issue?
  • srt1
    • Aug 2013
    • 177
    • india
    Re: Denon AVR 390 Volume not increasing
    anyody can give SM of this unit
    • srt1
      • Aug 2013
      • 177
      • india
      i did factory reset .. now everything fine ... i searched alot to get its service manual but i didnt find. at last i found its in youtube video from there i could understand how can do reset (button combination)
        Good job figuring out the answer to your problem.
        • freethink
          Kenwood KR-A70 Receiver Balance changes with volume controls?
          by freethink
          I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
          11-23-2025, 07:53 PM
        • Storyteller12
          Samsung Soundbar Q900T Cuts Off if Volume above 30
          by Storyteller12
          I have this soundbar and when I turn it on it works until I turn the volume above 30.
          Then the display show “PROT” protection and shuts off.
          I can turn it right back on and it works until volume hits 30 again.
          There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
          I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
          It will play fine for hours with volume...
          03-21-2023, 12:31 PM
        • karthur
          Vizio D65x-G4 Volume changes on its own
          by karthur
          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
          06-05-2025, 08:13 AM
        • Coert van Dorsten
          Sansui Integrated Amplifier replacement volume control troubles
          by Coert van Dorsten
          Hi all you clever electronmic gooroos!
          I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
          10-15-2025, 02:54 PM
        • crackedprint
          Sony HCD-HX80R Amplifier Volume Control Problem
          by crackedprint
          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
          I have tried a Cold Reset as per the service manual.
          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
          I have looked all the way through the service manual and tried many online...
          01-21-2025, 12:18 PM
