NAD T751 left channel dead
  • mips
    • Jan 2012
    • 20
    I noticed today that there is no sound output from the left channel of my nad t751 a/v receiver. Only thing you hear occasionally is a scratchy/crackling sound almost like when trying to manually tune a fm radio.
    Where do I even start to try and identify what lost it's magic smoke so I can try and repair it? Still need to go hunt for schematics as well.
    Thanks in advance.
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Re: NAD T751 left channel dead
    Is this happening on all audio inputs ( radio, cd, 5ch in, aux, etc. )?
    See if there is audio signal on the left channel pre-out rca connector and on the headphones.
    • mips
      • Jan 2012
      • 20
      Yes all inputs.
      I'll have to check the pre-out, dunno how to check the headphone jack.
      • madan1
        • Nov 2016
        • 682
        • Bulgaria
        plug in headphones
        • mips
          • Jan 2012
          • 20
          plug in headphones
          I don't have any
          • CapLeaker
            Leaking Member
            • 8158
            Can we have some pictures to see? Here is the Service Manual for it.
            • mips
              • Jan 2012
              • 20
              Thanks for the service manual.
              What would you like pics of and I'll take some?
              • madan1
                • Nov 2016
                • 682
                • Bulgaria
                Did you check the headphone output and the pre-out outputs?
                What about the surr outputs - are they working?
                What about digital audio signal?
                If the problem is affecting only 1 channel and the unit is powering up, my guess is that at least the power amp section is OK. Now you will have to find where the signal is lost. It could be faulty relay, bad board connection, bad op-amp, etc.
                Do the above test to narrow down the options.
                • mips
                  • Jan 2012
                  • 20
                  Ok I have not done much about this but the weird thing is not so long ago both channels started working again and then back to left only. Today the left channel is dead but the right channel now works, wtf!?!?
                  I dunno if it's my imagination but the relay no longer sounds the same when it kicks in, it use to have a lot louder click from what I recall.
                  • Sik_6ty_Sixx
                    HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                    by Sik_6ty_Sixx
                    So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                    02-18-2025, 05:06 AM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • HelpMeRepair
                    Yamaha RX-A3010 left channel no signal
                    by HelpMeRepair
                    Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
                    what I did so far ,
                    factory reset
                    test all other channel
                    tone test
                    dissasemble and look , visual inspection witout full dissasembly
                    looked at all the mosfet for temperature to see if they eas operating
                    scratch my head couple of time
                    thanks in advance all help is appreciated , service manual are welcome too ! =)...
                    11-14-2024, 02:48 PM
                  • eccerr0r
                    old X58 triple channel board... memtest86 memory speed?
                    by eccerr0r
                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                    06-28-2025, 09:06 AM
                  • CDNBrewer
                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                    by CDNBrewer
                    Hello Everyone,
                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                    Symptoms:
                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                    • I swapped the Left and Right surround
                    08-05-2025, 09:29 PM
