NAD T751 left channel dead
  • mips
    • Jan 2012
    • 20
    I noticed today that there is no sound output from the left channel of my nad t751 a/v receiver. Only thing you hear occasionally is a scratchy/crackling sound almost like when trying to manually tune a fm radio.
    Where do I even start to try and identify what lost it's magic smoke so I can try and repair it? Still need to go hunt for schematics as well.
    Thanks in advance.
  • madan1
    • Nov 2016
    • 670
    Re: NAD T751 left channel dead
    Is this happening on all audio inputs ( radio, cd, 5ch in, aux, etc. )?
    See if there is audio signal on the left channel pre-out rca connector and on the headphones.
    • mips
      • Jan 2012
      • 20
      Yes all inputs.
      I'll have to check the pre-out, dunno how to check the headphone jack.
      • madan1
        • Nov 2016
        • 670
        plug in headphones
        • mips
          • Jan 2012
          • 20
          plug in headphones
          I don't have any
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8000
            Can we have some pictures to see? Here is the Service Manual for it.
            • mips
              • Jan 2012
              • 20
              Thanks for the service manual.
              What would you like pics of and I'll take some?
              • madan1
                • Nov 2016
                • 670
                Did you check the headphone output and the pre-out outputs?
                What about the surr outputs - are they working?
                What about digital audio signal?
                If the problem is affecting only 1 channel and the unit is powering up, my guess is that at least the power amp section is OK. Now you will have to find where the signal is lost. It could be faulty relay, bad board connection, bad op-amp, etc.
                Do the above test to narrow down the options.
                • mips
                  • Jan 2012
                  • 20
                  Ok I have not done much about this but the weird thing is not so long ago both channels started working again and then back to left only. Today the left channel is dead but the right channel now works, wtf!?!?
                  I dunno if it's my imagination but the relay no longer sounds the same when it kicks in, it use to have a lot louder click from what I recall.
                  • Sik_6ty_Sixx
                    HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                    by Sik_6ty_Sixx
                    So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                    02-18-2025, 05:06 AM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • HelpMeRepair
                    Yamaha RX-A3010 left channel no signal
                    by HelpMeRepair
                    Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
                    what I did so far ,
                    factory reset
                    test all other channel
                    tone test
                    dissasemble and look , visual inspection witout full dissasembly
                    looked at all the mosfet for temperature to see if they eas operating
                    scratch my head couple of time
                    thanks in advance all help is appreciated , service manual are welcome too ! =)...
                    11-14-2024, 02:48 PM
                  • xfreakx
                    Yamaha XP7000 Crackling in left channel
                    by xfreakx
                    Hi guys,
                    I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
                    The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
                    While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
                    I switched the mono blocks for a test to make sure the error is in the block itself...
                    06-29-2023, 05:30 AM
                  • erickeri1234
                    Sony str-dn850 home receiver no left channel.
                    by erickeri1234
                    Ok start off by saying I have some tv repair but not much on the receiver end.
                    Picked up a Sony str-dn850 home receiver when I first plugged it in powered it up it came on and the system check relay clicked and about 3 seconds later it went into protection mode.
                    I powered it off and on. Comes on no problem.
                    Hooked up speakers and it started to pop and crackle but the volume was all the way down.. and I was only getting that sound out of the left channel. Right channel had no sound.. but every time I turn the volume up it has a smell crackling sound on ever volume number......
                    10-04-2021, 07:45 PM
