Altech lansing pc speakers and subwoofer RIP? coil ohm values.
  • gretter74
    • Feb 2016
    • 10
    • Denmark
    Altech Lansing pc speaker system gave in after 10+ years. A few pops in the sound and then... gone.
    ...but I love them.
    I've opened up the subwoofer and looked in side. No mechanical problems, no weired smells or apparently blown caps.
    Meassuring resistance on a fuse gives
    2 ohms.
    There's a transformer.
    Primary side 800k ohm
    Secondary side 0.9 Ohm.... that seems wrong.
    Is it possible for anyone to confirm that, That seems to be the problem?
    There are no specifications on the transformer.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Altech lansing pc speakers and subwoofer RIP? coil ohm values.
    Why don't you measure the resistance directly between the minus and plus of the speaker ? , it should give between 4Ohms to 16 Ohms , depending on specific designs . This way you can narrow the culprit .
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Primary = 800k? That sounds awfully close to "open" to me. Does the transformer have a thermal fuse in series with the primary, perhaps?
      Secondary sounds about right (relatively low voltage, relatively high current, which is to say, not many turns of thick-ish wire).
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        +1
        That primary winding is gone, you are probably reading your body resistance.
        Right now you probably do not have DC Voltage from that power supply.
        • gretter74
          • Feb 2016
          • 10
          • Denmark
          Thank you guys.
          There's no power from the supply.
          The speaker is ok. 4 ohms.
          I'll look around for a new transformer. The only identification is a number '0237'. I dont suppose that's enough to go on. Perhaps I can find a diagram some where.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Forget the transformer and its markings. Just see what IC(s) are used for driving the speaker and what is the rated voltage of the filter caps - that should give you a good enough clue of what to use for the power supply output. You may even get away with a cheap switchmode adapter/PSU (like a laptop adapter) - or at least for testing. As far as current rating for the adapter/transformer - worst case scenario would be if you have a BTL chip driving the speaker. In such a case, take the input voltage and divide it by the voice coil static resistance, then add 25% to that value for safety margin. If the speaker has dual voice-coil, the current would be two times that amount.
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • rustinjust
              Please help, subwoofer connected to tv, read description below
              by rustinjust
              I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
              Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
              Is there a way of...
              10-28-2023, 07:09 AM
            • rustinjust
              Please help, where can I get a remote for my subwoofer?
              by rustinjust
              I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
              Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
              Is there...
              10-28-2023, 03:43 AM
            • rashidjafar
              Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
              by rashidjafar
              I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
              Values for :-
              PC43 : Capacitor [3x1.5mm]
              PL7 : Inductor [2x1mm]
              PC39 : Capacitor [1x0.5mm]
              Any ideas would be appreciated.
              I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
              08-07-2025, 05:10 PM
            • chth96
              How can I test coil whether it is really broken or not?
              by chth96
              I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
              I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
              I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
              I want to replace this round black fuse and unidentified coil if it got broken.
              02-20-2024, 01:07 AM
