Dead Aiwa AV-D50
  • jworthin
    • Feb 2017
    • 33
    Dead Aiwa AV-D50
    First post.
    This Aiwa receiver does not power up. Checking supply voltages reveals the VM line is not coming up. Should be +11.6V. The power regulator transistors are not getting bias current via Q107 but I do not understand why. It seems the bias comes from circuits after the regulator transistors that are nearly turned off. These transistors and diode test okay.
    Measured voltages:
    Q109 E 26.35
    B 25.77
    C 1.470
    Q108 E 26.35
    B 25.77
    C 1.470
    Q107 B 0.385
    C 25.78
    E 0.005
    Q106 E 0.0
    B 0.0
    C 0.385
    Q105 E 1.330
    B 1.309
    C 0.0
    D101 anode 0.0
    cathode 1.370
    Note the power transistors pass more current (as they warm up?) so some voltages tied to them that should be the same are slightly different as I measured them at slightly different times.
    Any help would be greatly appreciated. I have been trying to figure this out for days now.
  • petehall347
    • Jan 2015
    • 4423
    • United Kingdom
    Re: Dead Aiwa AV-D50
    quick look says its very likely in protect mode .
    is the negative rail ok ?
    • jworthin
      • Feb 2017
      • 33
      There are two relays RY101 and RY102 that when closed supply transformer AC to the B+- rail bridge and filters (about +-50V). The relays are not yet closed so the rails float at +-25V.
      • jworthin
        • Feb 2017
        • 33
        This unit has no separate stand by supply. I believe this VM voltage is used to feed further regulators for 3.3V and 5V for the power button and remote controller. I think it needs to come up first.
        • petehall347
          • Jan 2015
          • 4423
          • United Kingdom
          them damn pnp transistors always throw me out .. i fully understand npn ..pnp are a bloody nuisance ...
            Can you please upload the full service manual?
            • madan1
              • Nov 2016
              • 670
              • Bulgaria
              There you go... it looks like a total mess to me .. so glad the new receivers use much more simple voltage regulator circuits.
              • jworthin
                • Feb 2017
                • 33
                Aiwa AV-D50 SM
                • jworthin
                  • Feb 2017
                  • 33
                  Is the biasing network R119, R120, R122 supposed to turn on Q108 and Q109 and then Q106 reduces over voltages based on the zener D101?
                    OK, I hope you can follow the operation of the circuit:
                    See that current sensing resistor R143? In normal operation, the current drawn by the load will not cause enough Vdrops on that R143 so NO BIAS for Q105 so it is OFF which makes Q106 to be OFF, so the Collector Voltage of Q106 will be high so Q107 is bias ON which will bias ON Q108, Q109. Q105, Q106 re part of the Latch/Protection circuit.
                    You only show part of the circuit so I really do not know exactly what you have and do not have.
                    If too much current flow through R143 then Q105, Q106 will be ON so Q107 will be OFF so Q108, Q109 will no longer have the bias to be turned ON.
                    Notes: Q108, Q109 are not completely turn OFF they are bias on a little by R119 so you will have little output Voltage to keep the protection/latch active until the you cycle the power to reset.
                      Originally posted by jworthin
                      Aiwa AV-D50 SM
                      I get this message "Invalid Attachment specified. If you followed a valid link, please notify the administrator" when trying to download it.
                      • jworthin
                        • Feb 2017
                        • 33
                        The collectors of Q108 and Q109 are at 1.47V well under the 11.6V output needed. It seems like the over current protection circuit should not be activated. Also the base of Q106 is 0.0V. Seems like in this state Q108 and Q109 SB conducting.
                        The full manual is posted in #7. Please see page 18.
                          See post 11 as to what happen when I try to download your manual.
                          If the E-B junction of Q106 is at 0V, then what do you have on the Collector of Q106? 0.385V?
                          What is the feeding Voltage to the Emitter of Q108/109?
                          Once the latch is activated by the over current, the output will drop down to that low Voltage to keep the latch in place until you recycle the main power.
                            BTW, you need to test the resistance of R119: 4M7 resistor.
                            • jworthin
                              • Feb 2017
                              • 33
                              Please try the SM from #7 (madan1). That download works for me.
                              Collector Q106 is 0.385V (see measurements in #1)
                              I tried using my Fluke to record max current thru R143 on power up and there was no current surge. I also tried (risky) shorting R143 to prevent an over current detection with unchanged result.
                              Could you please explain the overcorrect latch? I do not understand how it works. Thanks.
                              • jworthin
                                • Feb 2017
                                • 33
                                R119 is 4.73M unfortunately.
                                  Take out Q106, right now Q107 is not getting enough bias to be ON.
                                  • jworthin
                                    • Feb 2017
                                    • 33
                                    Do you think the .385V Q105 base should be biasing it on?
                                    • jworthin
                                      • Feb 2017
                                      • 33
                                      If I take out Q106 might the VM line shoot up to 25V? (Since that also takes out the zener regulation.) Could that blow out other parts?
                                      • jworthin
                                        • Feb 2017
                                        • 33
                                        I removed Q106 and the output voltage indeed goes up to the full 25V.
                                        Does this mean Q106 was bad or the current protection WAS tripping somehow?
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
