SAMSON DB500A Repair.
  • capwizard
    • Jun 2016
    • 1991
    A very nice PRO PA Amp: SAMSON DB500A is power on not in the protection mode.
    PS: The problem is I forget what was the problem?
    PS: I called him, he said " no sound from iphone input"....I said " Bring me the input cable, I need to check it."
    Hartke Systems: SAMSON DB500A PCB is like a piece of art, so beautiful.
    http://www.samsontech.com/hartke/
    LINE Combo Balanced Input
    For added convenience, the dB500a employs a Combo connector that accepts a standard XLR mic cable for balanced line level
    signals, or a standard 1/4" instrument cable for either balanced (TRS – TIP/RING/SLEEVE) or unbalanced (TS – TIP/SLEEVE) line level
    signals. The LINE input can work simultaneously with the Mic input so it is possible to use a microphone while playing alone with a
    keyboard that is plugged into the dB500a’s LINE input. You can control the LINE input by using the LINE LEVEL control as described
    in the previous page. For more information on cable and wiring, see page 13 of this manual for a detailed wiring diagrams
  • capwizard
    • Jun 2016
    • 1991
    Re: SAMSON DB500A Repair.
    Testing; A standard 1/4" instrument cable with cellphone stereo adapter inputs to the Amp, it has no sound! Relay makes click click noise. I thought was input cable problem. The fact is that the amplifier is the issue.
    • capwizard
      • Jun 2016
      • 1991
      Help!....The amp starts at 0.5ma then in 3 minutes go up to 3.5 A gradually , the AMP MOSFETs burn my finger, it stops until overheat relay clicks and clicks again. Isolate the preamplifier is still the same thing!
      PS: Can't find any shorted diodes or Trs.
        "the AMP MOSFETs burn my finge" What AMP MOSFET? Those 4 (+2 small transistors) attached to the heatsink that you can barely put the fingers on?
        • capwizard
          • Jun 2016
          • 1991
          Maybe they are NPN PNP, they are upside down, I can't see the parts No. Looks like amplifier noise harmonic vibration but current goes up gradually.
          PS: Should I take out that 4 TRs and test again.
          PS: They are 2SC5200 and 2SA1943, I cut their legs. Now I have time to test DC voltages are +50V and -50v.
          The Current still go up gradually.
          PS: I cut the last two power TRs legs, current stop at 0.246A, and the two TO-202 still get hot.
            https://www.badcaps.net/forum/attach...5&d=1487194391
            There are 8 large Transistors, which one are getting hot? The output of the power amp showing DC >1V?
            • capwizard
              • Jun 2016
              • 1991
              This is like heart bypass surgery! I found the transistor Q10 2SC3202 produce a lots heat.
              PS: take out Q10 test it is good. Amp still has current at 0.147A, and I can smell something is heating up it has new plastic smell. New I need a infrared camera instead of my fingers.
              PS: I bet you it is A leaking diode.
              "the power amp showing DC >1V?" They have speaker protection relay.
              PS: Check nearby capacitors are OK.
              At front two are MOSFETs as voltage regulators for DC voltages +50V and -50v (tested OK). The rest PNPs and NPNs all get hot to untouchable.
              • capwizard
                • Jun 2016
                • 1991
                New discovery: If I put the Daughter-board back to amp the 7915ct -15v is at -8.45v, 7815ct is ok +15v. The source input voltage is wrong.
                PS: At 5:00 I need to fix Sprinklers, See your guys tomorrow.
                • CapLeaker
                  Leaking Member
                  • 8178
                  so either the -15 volt regulator is bad, or something is dragging the -15V rail down. Like a bad op amp.
                  • capwizard
                    • Jun 2016
                    • 1991
                    The + - 25.4v are from AC transformer AC 18v then regulate to + - 15v DC which have problem.
                      So the - 25V is still at -25V when the output of the -15V is at -8V?
                      Is the -15V reg getting quite hot?
                      If the output of the -15V is only 8V then the Vdrops on the -15V reg is 17V (25V -8V) instead of 10V Vdrops so it should get quite hot.
                      You can try replacing the Reg IC or isolate loads to see which is loading down or it can be bad reg IC.
                      • capwizard
                        • Jun 2016
                        • 1991
                        If I open J4-A then - 15 is OK.
                        J4 is for pop cancel circuit U12 TA7317P but they modified to this(pic3).
                        PS: If I take out this Add-on board, the Amp still get hot then I cut the all the TRs legs.
                        • capwizard
                          • Jun 2016
                          • 1991
                          Keep on Troubleshooting.......
                            So U12 speaker protection is not used in this unit?
                            That U12 does the delay turned on and also shutdown the speaker relays if it detects DC on the output of the amplifiers, very old IC that has been around for a long long time, it is used a lots in the stereos.
                            So the speaker relays are coming ON?
                            I still do get the answer on the DCV at the outputs of the amplifiers (it is Bi-AMP system).
                            • capwizard
                              • Jun 2016
                              • 1991
                              Unbelievable this Amp use DC200v. Isn't this the OCL amp.
                              PS: i can't measure the DC voltage of the Amp output After I was scared and I cut the TRs legs. Beside this amp has a protection relay or I can still measure the output dc voltage?
                              PS: Do you mean the High-out and Low-out over the relay? I put the Add-on board and measure the relays are 0v.
                              AC current at 0.145A. If I put back Q10 will get hot and AC current is at 0.188A.
                                The Low frequency amp section is Class G, the high voltage is switched in by Q49, Q50 supply to the output section when high audio output needs to go high OUTPUT for short period of time, otherwise it runs on 55V.
                                HITACHI came out with that topology in the 70S.
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  I think we found the problem.The Q10 is over here(pic1). I took out the Q10 it tested OK!
                                  The voltage of Q10 (2SC3206) is B - C - E : 6.9v - 55v - 6v When no input the TR Q10 leg E should be 0V.
                                  PNP Q20 (2SA1024) B C E is at -6.7v -55v -7.3v
                                  Compared to other side of Amp Q36 B C E is 1.2v 54v 1.8v...................... Q37 B C E is -1.2v -54v -1.8v
                                  Q31 (2SC3902) B C E at -1.3v 1.8v -1.9v Q22 B C E at -4.8v 7.3v -0.1v
                                  Q9 B C E at 6.5v 54v 6.1v Q11 B C E at -5.9v -54v -6.2v (Both are Hot)
                                  Q38 B C E at 1.1v 54v 0.5v Q39 B C E at -1.2v -54v -1.2v
                                    As I asked, what DCV do you have at the output of both amplifiers (low freq and high freq)? I have a feeling that one of the amp has high DC OFFSET right now.
                                    Q22, Q31 are part of the active Bias for the output transistors.
                                    "When no input the TR Q10 leg E should be 0V" what do mean by NO INPUT?
                                    Q10, 20, 36, 37 should have E-B forward junction Voltage of around 0.60V.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      what DCV do you have at the output of both amplifiers, Both channel DCV are 0.0v.
                                        https://www.badcaps.net/forum/attach...5&d=1487270736
                                        You indicated Q10 Emitter (connected to R78; 220 Ohms) is 6V so what what is the DCV on the other end of R78?
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
                                        • JTaylor
                                          Allen and Heath Xone S2
                                          by JTaylor
                                          Hello everyone.
                                          I am trying to repair an Allen and Heath Xone S2 mixer but need a schematic. I found the service manual on line but it is missing 4 pages.
                                          When an input is connected to one of the four line / phono input channels I can hear the music in the cue / headphones but there is no output on the master, the input faders are doing nothing. I can connect the sound input to the mic / line inputs or the external input boards and there is sound on the master output. One of the 74HC4053D Multiplexer/Demultiplexer had blown on the slave PCB so I changed this, I also changed two of...
                                          05-02-2025, 08:08 AM
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
