Adding a AUX Jack to this 80's Delco AM/FM STEREO
    Re: Adding a AUX Jack to this 80's Delco AM/FM STEREO
    BTW, I got the Left and Right channel AUX input Jack reverse left and right.
    • Fisher77
      • Feb 2016
      • 229
      Ok, no worries, I couldnt tell it. I will swap them when I do the final install, still have to drill a hole in the face, and modify a spot on the case to install the jack. I will post a pic of it when I get it all done.
      I really appreciate your help with this budm. I looked at it for several days. I figured the input would have to go through the orange, and green wires, but had no idea how to hook into it, and where to ground it. I am still learning about this stuff when I have time to sit down and work with it. I have 2 plazma tv's I am looking at now. I may be posting about them as well.
        How does it sound any way?
        I did the mod for my 1977 TransAm.
        • Fisher77
          • Feb 2016
          • 229
          Sounds great. Plug in my phone and it switches right to it. Unplug it, and it goes right back to the radio. Sounds just as good, and as loud as the radio. Mine is going in a 85 short wide GMC Sierra Classic.
          • Fisher77
            • Feb 2016
            • 229
            Here is the finished radio. Thanks for all the help budm.
              Glad to see the finished products. I saw lots of info on the web for these old car stereos, some of them are pretty expensive on EBAY.
              • Fisher77
                • Feb 2016
                • 229
                I searched around the net for several days trying to find out how to hook the aux jack up to this one. Found several other models, but not this one. Even found videos, but the guys were advertising installing a jack for you, not how to do it. I wanted to go back with an original radio in my pickup, or as close as I could, (I think the Sierra Classic's came with cassette radios). I looked on ebay, but as you said, they are pretty pricey. I happened to wonder into a second hand store one day just to look around, and lucked into this one for $5. At the time I had no idea if it would even still work, but for $5, I was willing to take a chance. Glad I did.
                • Geeker007
                  9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                  by Geeker007
                  Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                  I am new to electronics repair, so my queries could be naive but I am ready to learn.
                  So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                  01-28-2025, 03:31 PM
                • wnlewis
                  New wire for my RDE3340 Whirlpool electric range
                  by wnlewis
                  OK. I got the rocker switch figured out thanks to the good advice on this forum.
                  Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                  This is a Whirlpool RDE3340 electric range.
                  The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                  Where may I find parts...
                  01-08-2025, 11:21 PM
                • emeskay
                  Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                  by emeskay
                  We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                  08-06-2024, 07:13 AM
                • YOUCEF4787
                  Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                  by YOUCEF4787
                  I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                  Initial Problem:
                  The laptop was completely dead, no signs of life, no power LED.
                  Action Taken:
                  I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                  Current Situation & The Main Issue:
                  The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                  09-21-2025, 12:19 PM
                • technicalspecialist
                  Vintage fan repair, copper wire question
                  by technicalspecialist
                  I currently have a customer's vintage fan on the work bench to repair.
                  It uses an induction motor with 4 poles. One of the poles is open.
                  I couldn't find the break so i cut off the original wire.
                  I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                  I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                  The enamelled copper...
                  03-16-2023, 12:54 PM
