Onkyo HT-R690 AV Receiver Front Right Channel Not Working
  • sfernandes
    • Oct 2013
    • 229
    Re: Onkyo HT-R690 AV Receiver Front Right Channel Not Working
    Come on dudes someone has to know where I could check from here. I would like to not throw this out if possible. I have been doing research and watching videos on troubleshooting, but still having issues. Please help.
      Look at PDF page 7 which is the Block diagram, you will see FR comes out from IC Q4001 pin 21, FL pin 23.
      Those two output signals are fed to the connector P6600B (PDF page 11).
      So those are where you need to trace and find out if you have audio signals there or not.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Originally posted by sfernandes
        I repair TV's all the time not knowing ohms law and not knowing schematics. I guess receivers are different.
        No it is not different. To repair TV's then you must understand circuitry? If not you must be guessing at what is wrong, then you are lucky you have not zap yourself with a good amount of voltage. Ohms Law explains how voltage, current and resistance is represented in a circuit. It is so basic and simple. From Ohms Law power can be understood.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          [QUOTE=budm;684860]Look at PDF page 7 which is the Block diagram, you will see FR comes out from IC Q4001 pin 21, FL pin 23.
          So those are where you need to trace and find out if you have audio signals there or not.[/QUOTE
          Thanks BudM for the page correction. I had just look at the first diagram and did not see the small letters for the model number.
            Correction! PDF page 10, NOT 11, disregard about the connector P6600B in post #22.
            • sfernandes
              • Oct 2013
              • 229
              Thanks guys I'll have a squiz at it when I get home from work this evening and I'll post my findings.
              • sfernandes
                • Oct 2013
                • 229
                I'm looking all over the place for Q4001 I can't find it.
                  PDF page 7 & page 10 Board # BAAF-0621
                  • sfernandes
                    • Oct 2013
                    • 229
                    I don't see any board by that name. What's on this board? Is it the HDMI board?
                    • sfernandes
                      • Oct 2013
                      • 229
                      All my boards start with bchdm
                      • sfernandes
                        • Oct 2013
                        • 229
                        Well not all, but I looked at every board I don't see any with the name baaf
                          Audio input, it has connectors p5502b, 5503b, 5504b, PDF page 10.
                          • sfernandes
                            • Oct 2013
                            • 229
                            Ok found it. It's called BCAF 0621 no wonder I couldn't find it. I'm happy I looked for the numbers instead. So I'm assuming this IC is in the bottom correct? If so how is it possible to probe it playing audio with the whole unit apart and all boards disconnected?
                              PDF page 2 Exploded view # U0010.
                              PCB Part list page 53, Q4001 listed on page 56.
                              You NEED to look at the service manual.
                              I looked at 130 pages.
                              • sfernandes
                                • Oct 2013
                                • 229
                                I have the manual open on my laptop next to the unit.
                                • sfernandes
                                  • Oct 2013
                                  • 229
                                  So what are you saying? I'm not understanding. I'm looking at the manual at the pages you told me.
                                    Well look at page 2, page 7, page 10, page 53 and see how they all are related to each other.
                                    • sfernandes
                                      • Oct 2013
                                      • 229
                                      Is this ic on the bottom? Do I have to strip this thing down? If so how would I test it? Build it on my carpet with no chassis?
                                      • sfernandes
                                        • Oct 2013
                                        • 229
                                        I'm looking at those pages I can't see any relation. The first page shows how the unit comes apart and the others is a block diagram and a schematic.
                                          I do not know I do not have the unit or the board in front of me but you now know where the board is so now you need to figure out how to get to it to look for the IC and how to get to it to test it.
                                          If it is going to be easy for beginner then every body can do it, but it is not for beginner.
                                          • CdDvdFlash
                                            DSE GE6878 possible TV receiver dying remote not working well
                                            by CdDvdFlash
                                            For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                            07-03-2024, 03:55 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • Deedeelabricolade
                                            JVC TH A35 Home cinema repair, only sub and center channel working
                                            by Deedeelabricolade
                                            So I have this home cinema with only the subwoofer and the central speaker working. The unit boots up with blue light, so no protection mode nor short detected. All fonctions are available (radio, cd, aux etc...).
                                            I have the schematic of it but no idea what to look at and how. Seems that the sub and center speaker are both connected to the same relay but I don't get how the 3 other have failed as they are all powered from the same supply?​ How can I diagnose it safely?
                                            Electronics forum for electronics experts to repair defective appliance.
                                            09-30-2024, 02:01 PM
                                          • redbaron1007
                                            Onkyo HT-R510 turns on and then immediatly off
                                            by redbaron1007
                                            I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
                                            Here's everything I've done so far.
                                            The first thing I did was open it up and check for any burn marks exploded parts...
                                            11-14-2021, 09:55 PM
