Fosgate Prime R500-1 car amp
  • northpoint
    • Dec 2012
    • 41
    I am posting here because I do not know of any good electronic repair boards but badcaps (Not buttering up anyone, Im serious). I was given this amp and its a 'moral imperative' that I repair it. If I am totally off base posting here then please redirect me to somewhere else
    Person I got it from said it basically had no output. Ok, So got it on the bench and started testing the mosfets on the amp section. It appears the mosfets on one channel are bad. No physical damage at all anywhere. But the gates appear to be blown. The mosfet is a KTA1962A and I cannot seem to find it in the USA. I found it available on ebay from china and will need about 8 (4 per side, 4 extra just in case I have to replace the other side). Problem is I really would not want to wait a month for these chips. Cannot find a cross reference but do have the data sheet. Its a "Triple Diffused PNP Transister".
    Anyone know a cross reference or somewhere in States to get them?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Fosgate Prime R500-1 car amp
    I've used this site in the past. http://alltransistors.com/mosfet/crsearch.php
      'The mosfet is a KTA1962A'
      Well, the KTA1962 is NOT MOSFET, so are they bad in which way?
      How about uploading good clear pictures of what we are dealing with?
      • northpoint
        • Dec 2012
        • 41
        Im glad you asked. This made me go back and recheck my work and I screwed up. They are bi polar and are PNP not NPN. Makes a bit of a difference in testing.
        Testing - I am using a DMM to toggle the gate (base) on and off. Checked the emitter and collector basically the same. Perhaps I have the testing wrong and I will head back to the books too. sorry.
        I am learning.
        Pics of board and transisters from my cell phone cam:
          So what section of the so called bad Transistors are from?
          Do you have the boosted Voltages from the switching power supply section?
          BTW, I cannot read what are printed on the power devices.
          • northpoint
            • Dec 2012
            • 41
            Well, I have retested the transistors and they tested fine. I do not have a power supply for it available until friday when my new one arrives. Then I can get more into it. However, I wanted to kinda get a jump on it by testing the transistors. I incorrectly tested them the first time and thats all on me.
            On the origional pic in last post on the right side are the transistors that were in question. I see now that its a push/pull circuit setup. Below is a pic of the transistor I was testing. There are 4 of them and then their compliments on the other side of the board.
            There is a bank of 4 of them. Then on the other side of the board is a bank of the 5242's.
            To restate: Im sorry this whole thread is premature. I made a mistake in testing the transistors and thought they were bad. I then was having a hard time finding a supplier which I actually did finally find a comparable one at fairchild with a different part number.
            I have not really done a lot of board level work but have decided to get into it now so I am learning a lot. I just hate the stupid questions I may ask along the way.
            sorry to appear totally stupid here.
            Northpoint
              Just a push-pull Class A-B power amp, if the outputs are shorted you would have seen blown fuses, and those white power Emitter resistors would have blown open.
              BTW, there is no protection speaker relay to stop the unit from dumping large DC to the speakers if the output circuits shorted out. I would not connect any speakers to the output jacks until you verify that there is no big DC offset present at the output terminals.
              • hardwareguy
                • Jun 2006
                • 405
                Most car amps detect DC offset via the PSU rails.
                The theory being that if a rail gets dumped into a speaker, one rail will go low while the other will remain high. If this differential occurs, the PWM controller shuts down.
                I still prefer cutting the speaker outputs and I would test for offset every time you fix any direct coupled amp. Much over 15mV with the gain at minimum and I start asking questions, 50mV or more and I start changing parts. (What I change/test and in what order depends on the severity of the offset. 2V+ offsets are usually OPS faults, 20-200mV offsets are usually input stage faults. Some (crappy) designs may have high-ish offset naturally.)
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  2sa1962 and 2sc5242 are available at digikey.
                  the big filter caps go open more often than any other failure.
                  the supply with open cap goes low and the amp stays in protect.
                  • connorcc2005
                    Thermistor specs and cross reference
                    by connorcc2005
                    I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                    What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                    The physical diameter of the piece is 5.1mm measured with a caliper.
                    Other than what you see in the pic, there is no other writing on the part.
                    My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                    06-16-2022, 04:16 PM
                  • Geomih
                    Asus Prime Asus PRIME X670-P r1.01X (60MB1BU0-MB0A06) boardview
                    by Geomih
                    Couldn't find this particular board on badcaps so here it is for safe keeping...
                    08-16-2025, 01:52 PM
                  • raregtp
                    Voltage regulator cross-reference
                    by raregtp
                    Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
                    The first is:
                    A1
                    AS1117L-18
                    B0640 25
                    The second is:
                    A1
                    AS1117L-33
                    B0640 28
                    I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
                    If anyone can assist...
                    03-15-2020, 11:12 PM
                  • jasko_jacker
                    cross reference tps51285a
                    by jasko_jacker
                    I try to substitute the RT6575B with TPS51285A,
                    it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
                    12-07-2021, 01:49 PM
                  • speaktorob
                    Reference Nvidia GTX 980 ti - looking for a new shroud
                    by speaktorob
                    So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
                    Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
                    03-22-2024, 03:00 AM
