Very low volume on Sub
  • mikay786
    • Aug 2014
    • 765
    Working on this Monitor Audio Radius 360 sub that I got for nowt.
    It powers on and receives a signal but it barely produces any sound, I can just about feel the driver beating when I put my hand to it.
    Have tested all electrolytic caps and they are not too bad, changed a couple. Tested most transistors and seem ok aside from a couple that were reading slightly different to the others so replaced with new ones matching the others readings.
    Got one more transistor out but not sure what the readings mean and don't have anything to compare it too.
    Reads on transister tester as a BJT-NPN
    MPSA13
    hFE = 47.7k
    Vf = 1.19v
    is that normal?
    Next I'm going to check the C5198 & A1941
    Re: Very low volume on Sub
    Check the 20K Dual Volume pots for open circuit.
    It uses cheap pots for such an expensive sub-woofer.
    http://s807.photobucket.com/user/bud...?sort=3&page=1
    • mikay786
      • Aug 2014
      • 765
      Just about to remove it from board, how do I test it?
        Just check the resistance between the wiper (center pin) and each pin end as you rotate the shaft, also between end pins.
        • mikay786
          • Aug 2014
          • 765
          I think one of the pots is bad as is reading a bit funny
          On good pot it reads
          Pin 1-2 Variable depending on dial position, 3 Ohm up to 20k
          Pin 2-3 Variable from 20k to 45 Ohm
          Pin 1-3 20k Constant
          Pin 4-5 Variable depending on dial position, 3 Ohm up to 20k
          Pin 4-6 20k Constant
          On suspected pot
          Pin 2-3 all over the place, M ohms
          Pin 4-5 variable from 46 Ohm to 20k
          Pin 4-6 is 0.L
          Pin 5-6 is 0.L
          • mikay786
            • Aug 2014
            • 765
            What is the official name for right angle pin pots?
            http://www.ebay.co.uk/itm/DP-20K-Lin...4AAOSwT6pVkTEn
            Found tehse but the pins a straight
              I forget the manufacturer of the pot, it is on the back or the side of the pot.
              It is called Vertical mount with body support mounting tabs.
              I.E.:
              http://www.britishaudioservice.com/#...iometers/c15gn You can try contacting them.
              http://www.globalsources.com/gsol/I/...htm#1130293798
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Why don't you just clean the pot with Caig deoxit D5 and test again? I usually clean things 3 times giving it 24 hours between cleans. Fixes 40 year old pots, some I did 8 years ago and they still work perfect.
                sigpicThe Sky Is Falling
                  What I found wrong with the pot were bad contacts between the eye rivet of the terminal to the carbon trace on the the phenolic substrate, I tried recrimping it with long nose plier without permanent success.
                  You can easily move those terminals, they are just cheaply made pots.
                  BTW, it is dual-pot but only one pot is being used.
                    • 31115
                    i think the track is open-circuit at one end - cleaning wont help
                    i also think it should be log type, not linear for volume.
                      • 31115
                      does this device use the pot's threaded shaft and a nut to fix on the backplate, or is it just the pcb mounts used?
                      because:
                      http://www.rapidonline.com/omeg-2gec...ontrol-65-1444
                      and some short wires would work if it's fixed
                        I used the single pot for the replacement (it only uses one of the two-gang pots), soldered 5 small solid wires to the 3 terminals, and two 16AWG solid wires to the side of the body for the mounting support as original and to set it at the correct height.
                        • mikay786
                          • Aug 2014
                          • 765
                          Tried with switch cleaner to no avail.
                          They look pretty tight on mine, no pins that I would say are loose.
                          Uses both a nut on the shaft and like wedges on the underside of the base that are soldered to the board.
                          Ive ordered the ones from eBay as have used them before on another MA sub that I broke the pot on not knowing there was a nut!
                          I just cut off the legs from the old one, soldered the top legs on to the top 3 pins and bent the bottom 3 pins over to get it to fit.
                          • mikay786
                            • Aug 2014
                            • 765
                            Thanks budm / stj again, all sorted.
                              Glad to hear that it is fixed.
                              • karthur
                                Vizio D65x-G4 Volume changes on its own
                                by karthur
                                On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                06-05-2025, 08:13 AM
                              • crackedprint
                                Sony HCD-HX80R Amplifier Volume Control Problem
                                by crackedprint
                                I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                I have tried a Cold Reset as per the service manual.
                                I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                I have looked all the way through the service manual and tried many online...
                                01-21-2025, 12:18 PM
                              • BigOof
                                Marantz SR5007 popping on volume change and mute in Direct Mode
                                by BigOof
                                I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                12-12-2024, 06:15 AM
                              • Storyteller12
                                Samsung Soundbar Q900T Cuts Off if Volume above 30
                                by Storyteller12
                                I have this soundbar and when I turn it on it works until I turn the volume above 30.
                                Then the display show “PROT” protection and shuts off.
                                I can turn it right back on and it works until volume hits 30 again.
                                There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                                I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                                It will play fine for hours with volume...
                                03-21-2023, 12:31 PM
                              • mikey5791
                                Help on car amplifier only one channel works
                                by mikey5791
                                Hi all forum members,
                                Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                08-06-2025, 10:36 PM
