Onkyo TX-NR646 short IR range
  • tibimakai
    • Jan 2012
    • 3680
    I have picked this receiver up and after repairing it, I thought that I'm done with it.
    After putting it all back together and tried using it, the remote would not work.
    Replaced the batteries in the remote, reset the remote and the receiver. Updated the firmware also. No change.
    I have tried from a short distance and it is working from a couple of inches.
    I have took it apart and without the front cover, works up to a foot.
    It is a 3 pin type IR LED and it seems like, it has the right voltages. +3.3V, GND, 3.25V signal. The signal drops, when I hit a button on the remote.
    I have compared it, with a 636 receiver and that one, does the same thing.
    What could be the problem?
    IR LED part # IRM-3638M3S28
  • redwire
    • Dec 2010
    • 3912
    Re: Onkyo TX-NR646 short IR range
    If you have compact florescent, LED lighting, their flicker can upset the IR receiver. Try it in a dark room.
    A bad ground to the shell of the Rx module, a bad Rx module, bad Vcc decoupling cap at the Rx module, could make it have poor signal to noise.
    Small chance the remote control could be transmitting very weak IR. Check for a bent LED and bad decoupling cap in the remote.
    • tibimakai
      • Jan 2012
      • 3680
      I have tried it in the semi dark living room(in cabinet), then on the kitchen table disassembled, still the same.
      The only difference is that, assembled the range is even worse.
      The metal housing of the LED is all solidly soldered.
      I have three remotes and they all work from the same distance.
      I will have to check the capacitors. I will check the 3.3V with a scope.
      Thanks for now, I will update as soon as I'm able to test it.
      • ngvuanh
        • Jul 2013
        • 36
        You might have bad IR led too.
        • tibimakai
          • Jan 2012
          • 3680
          In the receiver?
          • ngvuanh
            • Jul 2013
            • 36
            Originally posted by tibimakai
            In the receiver?
            Yes
            • tibimakai
              • Jan 2012
              • 3680
              I have replaced the LED from the 636 and it is working now.
              I have placed an order, for a new one.
              • DynaxSC
                Extreme High Current & Low Voltage Short Killer ??
                by DynaxSC
                Hi Folks
                I'm looking for a extreme high current short killer solution for a reasonable cost.
                I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                After taking off the socket, the shorts dissappear again.
                The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                10-15-2024, 10:13 AM
              • Stephen
                MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                by Stephen
                I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                02-06-2025, 12:03 PM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
              • cstout
                DeLonghi AC Remote only accepts 3V
                by cstout
                Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                I can't find any schematics...
                06-03-2024, 03:53 PM
              • aaronkatrini
                Help me find the short circuit on this WORKING Nvidia GTX1650
                by aaronkatrini
                Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                04-18-2024, 03:15 PM
