Service Manuals for audio equipment
  • tech2014
    • Aug 2014
    • 807
    Does anyone know a good place for audio equipment schematics and service manuals?
    Also, how do you go about troubleshooting something without a schematic or SM? I can usually troubleshoot TV ok but amps are much mote difficult, especially since most of the boards in the amps are piled on top of each other, and usually the board I need to test is on the bottom. Once the other boards are removed, you can no longer test anything. Any tips?
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Re: Service Manuals for audio equipment
    You could try:
    www.schematicsunlimited.com
    As for your second question, hope for a blown fuse? 8^)
    • Khron
      • Sep 2006
      • 1350
      • Finland
      www.elektrotanya.com also has a fair selection (albeit with certain limitations in usage).
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        http://www.hifiengine.com/
        http://www.vintageshifi.com/
        • tech2014
          • Aug 2014
          • 807
          thanks Budm
          • Vinster
            • Feb 2016
            • 25
            Thanks for the links.
            Vin
            • jocondor
              • Feb 2016
              • 22
              • Italy
              try: http://www.eserviceinfo.com/
              • japlytic
                • Oct 2005
                • 2086
                At one time, audio equipment was easy to maintain and repair (as one book said); now with digital processing/control in modern units, this statement is no longer valid - for such units, having a service manual on hand is generally essential.
                • jocondor
                  • Feb 2016
                  • 22
                  • Italy
                  Yeah right!
                    LCD LED TV Service Menu Codes
                    TCL LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    10-31-2024, 03:58 AM
                  • Med-Tech
                    Medical Devices Service Manuals
                    by Med-Tech
                    Hallo, anybody know where to get service manuals for Medical devices (other than Franks hospital)? The problem I have is with a physiotherapy machine it shows nothing on the display and the green LED flickers.[
                    Thanks in advance....
                    05-24-2025, 05:43 AM
                  • Mark R
                    Marantz Model 150 Tuner "NULL" Adjustment..
                    by Mark R
                    I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                    Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                    12-30-2024, 03:18 PM
                  • samson7point1@yahoo.com
                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                    by samson7point1@yahoo.com
                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                    The player processes the audio signal using two different reference frequencies. The "R"...
                    04-30-2024, 11:22 AM
                  • AustinCER
                    Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                    by AustinCER
                    Hello, I currently have a Dell XPS 8940 in our office for repair.
                    Service Tag: HG1Y673
                    The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                    Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                    Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                    07-15-2025, 05:28 PM
