Old Stereo Cabinet shocking people
  • tech2014
    • Aug 2014
    • 807
    I got a very old cabinet style stereo. The customer says that they get shocked when using the radio. I took some pics of the unit and power cord. Would the shock come from a bad ground or possibly the power cord is bad. Any ideas?
    Re: Old Stereo Cabinet shocking people
    Only 2-prong non-polarized cord so there is no safety GND on the chassis.
    Can we see better pictures of the chassis?
    There should be a paper sticker that gives you the tubes layout and full chassis model on the console some where. It has been since the early 70's that I worked on one of these consoles.
    • tech2014
      • Aug 2014
      • 807
      I don;t see any stickers on the inside or on the chassis. Here are some more pics of the inside. I did measure some AC on the metal pieces on the radio side, around 1.2VAC. Some kind of AC leakage??
        It may have one of those paper cap connected between the AC and the chassis which they do fail badly.
        You do have some kind of AC leakage current. You will also see difference reading if you reverse the plug when you plug it into the AC socket.
        • tech2014
          • Aug 2014
          • 807
          Would it be possible to build a 3 prong modern power cord for this cabinet, and would this fix the AC leakage and shocking problem.
            Safety test.
              You need to check to see if the incoming AC wires has capacitor/s connected to one them and the chassis, or the power transformer may be bad.
              • SteveNielsen
                Retired Tech
                • 2327
                Yes and a 50/50 chance that the AC hot side is tied to the chassis depending on which way the 2 wire cord is plugged in.
                • tech2014
                  • Aug 2014
                  • 807
                  thanks, i will do the safety check tomorrow and see if capacitors are connected.
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    If you're reading 1.2vac from chassis to actual ground at an outlet then that's about what you'd see from neutral to ground due to the house wiring resistance (neutral and ground are bonded at the panel). That is of no concern and probably not causing the shocks. It doesn't indicate leakage or a bad transformer either.
                    That's a EZ81/6CA4 dual rectifier tube with a 6v heater next to the AC power transformer. That tells me that the the power transformer has a primary winding for 117v and at least two secondaries, one at 6.3v for tube heaters and one somewhere between probably 90v and 150v for the B+ voltage. But the primary winding is we want to deal with.
                    Each side of the transformer primary is tied to a side of the ac supply, one via the power switch on the supposed "hot" side. One is also connected to the metal chassis, that's "supposed" to be neutral when the 2 wire cord is plugged in the "right" way. To wire a three wire cord with safety ground cord to it, disconnect the side of the transformer primary from the chassis and wire that lead to the neutral wire (white) in the cord, wire the other primary wire to the hot wire (black) in the cord via the switch, then connect the green wire of the cord to the chassis. Of course you'll have to pull the chassis out of the cabinet to do this. You're also gonna want to replace those old power supply filter caps, they are well beyond their life expectancy.
                      I have never seen these consoles with power transformer has the neutral wired to the chassis especially when it is uses non polarized plug.
                      You can easily verify that by checking the resistance between the chassis and the AC plug.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Yeah, you're right. It generally isn't tied directly to chassis but through a capacitor to chassis, which isn't much of a safety measure at all and in some circles called the "death cap". I don't think they've actually caused anyone's death but sure pack a wallop nonetheless.
                        I was mixing it in my older brain with the old ac/dc 5 tube radios with series strung heaters and no transformer and old 2 tube record players with with the heaters and turntable motor strung in series.
                        • Longbow
                          • Jun 2011
                          • 623
                          You probably do have a shorted or leaky paper cap on the input. But my question is where are you touching when you receive the shock? The radio tuning knobs and face plate all appear to be plastic. Maybe the metal chassis of the turntable is acting like a return.
                          Is it plugged in?
                            The turntable is also attached to the chassis.
                            • DrDos
                              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                              by DrDos
                              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                              08-08-2025, 03:16 AM
                            • Tarot Superstars
                              Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
                              by Tarot Superstars
                              Hi.
                              I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
                              Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
                              Where in the circuit is the best place to solder the 3 stereo input wires?
                              This is the model and schematics:
                              https://www.manualslib.com/manual/91...7l.html#manual
                              10-31-2023, 03:23 AM
                            • Sik_6ty_Sixx
                              HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                              by Sik_6ty_Sixx
                              So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                              02-18-2025, 05:06 AM
                            • vestaviascott
                              Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                              by vestaviascott
                              I'm looking for the dial cord winding settings for this radio!
                              I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                              The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                              06-07-2020, 08:36 AM
                            • Xenon-Codex
                              Luxman T-230 tuner missing stereo
                              by Xenon-Codex
                              I got it partly working, but it mostly stays mono, or goes very distorted stereo if I turn the separation trimmer more. What else needs to be adjusted? Mono sounds clean. I think it may have cold joints as the L-channel drops also off at times.
                              01-25-2024, 12:22 PM
