Luxman T-230 tuner missing stereo
  • Xenon-Codex
    • 186
    • Finland
    I got it partly working, but it mostly stays mono, or goes very distorted stereo if I turn the separation trimmer more. What else needs to be adjusted? Mono sounds clean. I think it may have cold joints as the L-channel drops also off at times.
  • Mark R
    Does Changing Out Caps In A Tuner Effect FM Reception
    by Mark R
    "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
    I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
    Any Thoughts?
    06-11-2024, 07:04 PM
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • ugamazing
    820-02020 PPBUS_AON missing
    by ugamazing
    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
    02-05-2025, 04:21 PM
  • jpreza
    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
    by jpreza
    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
    Looking at the card, it appears to be missing the following:
    1x 1.0uH inductor - orange square
    2x...
    11-01-2024, 10:54 PM
  • Mark R
    Marantz Model 120 Tuner Craziness I am Stumped!
    by Mark R
    My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
    I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
    All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
    The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
    10-20-2023, 01:25 PM
