JVC receiver RX-5032VSL "OVERLOAD"
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    5.1 receiver. Powers on normally and after a few seconds "OVERLOAD" blinks on display and doesn’t activate speaker output relays.
    No power transistors shorted (2SB1560, 2SD2390 x5), output of each channel at 0V, no DC... Looks like a defective Protection detection.
    PROTECTOR_IN line is at about -0,1V instead of expected 5,1V in normal state, but inputs of detector circuit are normal (-B from all channels on PROTECTOR lines and 0V from outputs). Q1302 (KTC3200) presents -B voltage on each leg, this is not normal according to schematics. Changed and fixed it!
    It’s very important to screw ground tab EP301 when making tests with AMP board, because otherwise +B -B get ungrounded and this can damage amplifier.
    I’ve found other issues with this same transistor in Denon receivers. I fixed a AVR-1311 and AVR-1910 with defective KTC3200 in amp section. I think it’s not a coincidence.
  • Longbow
    • Jun 2011
    • 623
    Re: JVC receiver RX-5032VSL "OVERLOAD"
    Originally posted by Chungalin
    5.1 receiver. Powers on normally and after a Q1302 (KTC3200) presents -B voltage on each leg, this is not normal according to schematics. Changed and fixed it!
    So are you saying that you found a shorted transistor, and that an intermittent pcb ground caused the problem?
    Is it plugged in?
    • Chungalin
      • Jul 2014
      • 422
      • Spain
      No. It wasn’t that easy. That KTC3200 wasn’t shorted under the basic diode tests (B-E, B-C, and reverse), but it didn’t behave correctly under normal load operation. It wasn’t an intermitent condition, it was permanent.
      PCB ground didn’t cause any problem. I said that it’s important to screw at least that gound contact when making tests to the amp board. If you need to change some component on amp board, you don’t need to fasten all PCB screws each time you test it, but EP301 is absolutely required. One time I forgot to screw it and then it made a terrible UUUUUU sound. Luckily I unplugged it immediately and nothing bad happened.
      • bobale
        • Aug 2018
        • 14
        • Serbia
        Just to chime in, I was having the same OVERLOAD problem with RX-5032VSL. I expected one of the channels to be blown or something along those lines, but even with all the amp board disconnected I was getting overload message.
        To cut the long story short, always have good look around the protection circuit. In my case the problem was bad switching diode D1307. It was conducting in oppsite direction as well, and that was triggering the protection circuit.
        • Chungalin
          • Jul 2014
          • 422
          • Spain
          Thanks for the feedback. D1307 is a 1SS133. These yellow ones are common fails in protector circuits.
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
          • cook
            HP Power Supply 6632A: Fast Mode vs Normal Mode?
            by cook
            FAST MODE vs NORMAL MODE
            I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
            I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
            06-07-2020, 05:32 AM
          • CdDvdFlash
            DSE GE6878 possible TV receiver dying remote not working well
            by CdDvdFlash
            For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
            07-03-2024, 03:55 AM
          • JordanW
            Diagnosing NAD receiver -- unexplained shut-downs
            by JordanW
            Everyone -- I am trying to troubleshoot my NAD C740 stereo receiver, which either won't power on or won't consistently stay powered on.
            I will start by saying that I am a hobbyist, and while I am decently handy with basic DC stuff, I am more hesitant when it comes to mains-powered equipment (that is, reluctant to poke around with a multimeter when it is powered on)
            The central issue is that after a long period of non-use, the receiver powers on and all functions seem to behave normally, but after a couple of minutes, it powers itself off.
            If I attempt...
            01-02-2023, 11:43 AM
          • JayPoorJay
            TV that only has headphone out to receiver/amp
            by JayPoorJay
            Hello All... Grateful for this site!
            I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
            I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt...
            02-20-2022, 09:03 AM
