Pioneer VSX-520-K Protection problem
Re: Pioneer VSX-520-K Protection problem
Look for something common to all amplifiers like the - rail that feeds the emitters of the voltage amplifier transistor via R227 10 ohm. And also the +12v rail that goes to the 7.5k resistors that connect to the input transistors' emitters.Last edited by rievax_60; 09-10-2015, 08:29 AM.Comment
Hey folks, im back after a long time due to work load. OK as for updates, i manage to fix the amp as on the power amp side, a couple of regulators seems faulty triggering the protection circuit. Now the amp powers up perfectly, all relays clicking fine.
BUT, I measured using DMM @ 200mV setting,
Left speaker output there's -31.3mV present while the right side -7mV dc offset present. What do i do now? Checked the big caps, they read just fine and measure as it should using a cap meter.
All the driver amp transistors seems to be fine as well as none blown or short.
Update : All surround speakers and center speakers, L&R speaker outputs are working perfectly fine with all under 10.0mV. Weird.
Could it be the big caps failing intermittently?Last edited by DjKrish; 05-10-2016, 04:27 AM.Comment
30mV offset is not going to trip the speaker protection relay, the trip point is usually around a Volt or two to trip the protection circuit.Never stop learning
Minus 30mV present when volume at zero with no signal input and speakers unplugged. Ive let it run for couple of hours, still showing -30mV. Only the right channel. Left seems fine.Comment
That said, I just managed to cause DC on the INPUT of my VSX-520, taking out C206C with a loud bang! This is a good example why you should use the service manual, even when you're experienced and know what you're doing. I dived in without the manual, replaced the output transistors and also needed to replace the protection transistors as they were also dead-short. It has been well over a decade since I worked on electronic repair of this type and it seems things have moved a long way...
The protection trannies were marked C3200 and A992, which, back in my day you could have safely assumed would have meant 2SC3200 and 2SA992 but not now apparently! I should have used KTC3200BL and KSA992F - these codes didnt exist back when I did this for a living! I Feel a bit silly for not having checked - lesson learned the hard way!
I don't need the centre channel right now so I'm going to isolate B+ and B- for that channel, pull out the incorrect trannies and try again, if the rest still works I can order the right parts and use it 4.1 until they arrive lolComment
Can you explain what cause the DC offset on Speaker output?Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
