Onkyo tx-nr509
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Onkyo tx-nr509
    Hi all just wandering does any one have any experience with these receivers. I am bidding on one on ebay fairly cheap atm with no sound fault. Just wandering if any one has any info or experience with these if so let me know cheers.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Onkyo tx-nr509
    The DTS chip may need reflowing.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: Onkyo tx-nr509
      Ahh right cheers mate, I have read up about that also about a free scheme that Onkyo are running like an extended warranty so they might even fix it for me for free will have to see.
      • mmartell
        • Oct 2013
        • 3189
        Re: Onkyo tx-nr509
        Yes that is your best bet as a reflow seems a temporary solution.
        • tibimakai
          • Jan 2012
          • 3680
          Re: Onkyo tx-nr509
          Onkyo has a recall site, where do you punch in the serial number of the receiver and will tell you, if they will take it in for free warranty repair, or not.
          I would just skip that receiver, with this issue(no sound, no video).
          • mmartell
            • Oct 2013
            • 3189
            Re: Onkyo tx-nr509
            Is Onkyo accepting multiple units from the same person/address without original/any purchase receipt ?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Re: Onkyo tx-nr509
              I have send Onkyo Uk a message and they will be sending me a box to send them the receiver for a free repair !! Whoop
              • mmartell
                • Oct 2013
                • 3189
                Re: Onkyo tx-nr509
                Nice! I had a 609 done under that program. Took them a long time to stand behind their products but then they went at it balls out.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Re: Onkyo tx-nr509
                  Nice one, just sent it off fairly heavy tbh hopefully its sorted before the end of the month as customer needs it back asap but still good though haha.
                  • FrancescoV
                    Onkyo HT-R390 no sound output, video output ok
                    by FrancescoV
                    Good morning everyone,
                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                    The firmware reported is the following:
                    M:1.00/11107BLP
                    D:?.??/????????
                    O:1.00/11107AL
                    The DSP firmware given the question marks seems corrupt.
                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                    05-11-2025, 02:59 AM
                  • jjne
                    Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
                    by jjne
                    I have a TX NR414, well I have two actually which are both exhibiting the same issue.
                    The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
                    I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
                    Yesterday, 07:51 AM
                  • zahi
                    DSP dump BIN files for ONKYO TX-NR5009
                    by zahi
                    Hello everyone, I need DSP dump BIN files for ONKYO TX-NR5009, TX-NR3009, Integra DTR-80.3, PR-SC5509, DHC-80.3, DTR-70.3, I think also 5007 is the same, or other...
                    I have replaced the DSP chip, still not working.
                    Can you share please?​
                    04-25-2025, 04:32 PM
                  • roman-hartwig
                    Onkyo TX-NR828 - popping sound every 5 min
                    by roman-hartwig
                    Object: Onkyo TX-NR828
                    Problem: Popping noises in the right surround channel every ~5min
                    Service manual: available
                    After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
                    07-29-2023, 08:08 AM
                  • bios321
                    onkyo CR-725
                    by bios321
                    Hello
                    I restart an old topic Onkyo CR-725 board NCDG-8932, if someone can tell me the value of q941, c941, r941 and d941. thanks
                    02-09-2025, 03:10 AM
