DSP dump BIN files for ONKYO TX-NR5009
  • zahi
    • Sep 2022
    • IL
    Hello everyone, I need DSP dump BIN files for ONKYO TX-NR5009, TX-NR3009, Integra DTR-80.3, PR-SC5509, DHC-80.3, DTR-70.3, I think also 5007 is the same, or other...
    I have replaced the DSP chip, still not working.
    Can you share please?​
  • Tom_x
    Onkyo HT-R390 DSP dump
    by Tom_x
    Hi
    I need DSP dump for Onkyo HT-R390.
    DSP board: BCHDM-0678
    DSP firmware corrupted, i need dump for Q282 spi chip (25q16) or dump from similar model with same dsp board
    thx
    Tom
    01-11-2025, 03:57 AM
  • Tom_x
    Onkyo grand integra schematic!
    by Tom_x
    Hi friends!
    I'm looking for schematic diagram for Onkyo grand integra A-G10 (A-8890)
    speaker relays not activated, maybe protection circuit blocking.
    If i power on for a minute, and power off and on again, speaker relays activated and unit working.
    thx
    Tom
    12-02-2023, 01:30 PM
  • Rolin
    Onkyo/Integra DBS-50.2 Blu-Ray Player - Won't turn on or shuts off immediately.
    by Rolin
    I have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
    09-07-2024, 12:11 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • Mephysis
    DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
    by Mephysis
    Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
    I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
    03-27-2025, 02:34 AM
