Korg Polysix synthesizer
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Korg Polysix synthesizer
    Originally posted by stj
    i think your dead tester is just a transistor.
    look at the pdf i linked - page11
    I did look and have questions but I think I ought to start a new thread about this.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Tested the PSU board with a 15K and a 7.5K load on +15v test point with similar results for both. With the 7.5K load measured voltages ranged a volt or so higher than with the 15K load, the +15v trimpot did adjust all the voltages in both cases, however they all fluctuate by 1/2 to 1 volt or so, and unable to get it down to +15v, and -15v runs about one volt lower than +15v, meaning if the +15v reads +16v the -15v reads -17v. +5v never gets down to 5v either.
      • redwire
        • Dec 2010
        • 3906
        OK, so note the +15V is the master regulator. If it is wrong, it messes everything up: the -15V, the +/-5V too. The +/-5V regulator just gives 1/3 of the +15V regulator's output. The -15V part just mirrors the +15V.
        So I would first fix the +15V reg. If you can measure IC2 pin voltages, that helps. It's reference voltage should be around 1.8V (pin 8 to gnd) and (pin 5 to gnd).
        I would say IC2 (M5230L) is bad, or Q4 is bad. Overvoltage could have also killed IC1 (4558) as max. voltage for it is +/-18V.
        The power supply has a design flaw, namely that if one fuse pops (but not both) it can damage the IC's from reverse voltage.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Thank you. I have thought of that too. Should I measure IC2 voltages with or without a dummy load? Nevermind, I'll do both anyways.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            The regulator is working and the trimpot works but the voltages are still too high with or without a load. The balance between +15 and -15 is off by about 1v. Pin 8 (V ref) is not used in this ckt. Pin 5 (V adj) has 2.0v to 2.1v
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Problem solved. It was the big filter caps on the transformer secondary that I don't have replacements for. I subbed a 6800uF 56v cap for C14 (4700uF 35v) and a couple of caps in parallel;1500uF 50v and 1200uF 50v equaling 2700uf, subbed for C13 (2200uF 35v) and the PSU is operating perfectly now, with or without dummy loading. I've got +15v, -15v, +5v, -5v steady and ready, the v adj pot does it's job (I can get from 13v to 18v). I'll buy some proper replacement caps in a few days for them.
                Great job, I wonder the bad reading was due to AC ripple riding on DC due to poorly filter and caused the power supply to be unstable.
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  That's basically what I think too. The caps were unstable and passing too much AC ripple/noise. I wish I could have replaced them off the bat just due to their age. Would have saved some time but in the process I tested just about every other single component on the board so there's really no regrets there
                    I do not know how good your meter is, but since are not dealing with switching power supply, the AC ripple frequency is only 120Hz so you can set the meter to ACV to see the AC Voltage on the, it should be very low in 100's of mACV range.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4950
                      • New Zealand
                      #90
                      Good to hear you figured it out
                      Don't take this the wrong way but this is a good example of why they always say only play with trimpots as a last resort. You will need a very good voltmeter if you want to get the voltage back within that very tight spec in the service manual.
                      -David VanHorn
                        • 30985
                        also, this is 5 pages+ because you didnt just recap it first.
                        anything that old and i wouldnt even bother powering it up without a pre-emptive recap.
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Yeah, you're right, I've wasted so many pages and it's not about something really important like conspiracy fantasies.
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            I'll be ok with my DVM. The 20v scale can measure down to .01v so I can get it within specs.
                              • 30985
                              theorys - theorys!
                              and it's not like you can recap a government - pre-emptively cap a few members maybe, but that wont generally fix the problem!
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                LOL! True. True. Well, we'll see how many more pages it gets to because the PSU of this thing is just the beginning of the project. There are like 9 or 10 other boards in this thing!
                                  • 30985
                                  yes, i was just thinking about that, all those op-amps and the logic boards.
                                  lets switch to fixing your component tester - go link the red battery wire to the regulator input and see if it turns on when you connect the battery.
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Yeah, I already miss that little guy.
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      What would be the danger of significantly reducing the capacitance on C13 and C14?
                                      I tried a 1200uF in place of the 2200uF (C13) and a 1500uF in place of the 4700uF (C14). The output is the same with or without dummy loads. I checked AC ripple at the outputs and it is below 5mV, same as using the stacked caps for higher capacitance.
                                        • 30985
                                        it may not cope well with a varying load.
                                        • SteveNielsen
                                          Retired Tech
                                          • Jun 2012
                                          • 2327
                                          I'll eventually get the right spec caps for it when I can afford to. I'm a poor retired man on a fixed income All I have to use are salvaged parts. In the meantime I'm experimenting
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
