Sony STR-DE445 wont go out of PROTECT-mode
  • mtoivanen
    • Sep 2014
    • 9
    • Finland
    Hi! I got Sony STR-DE445 for free because it originally had weird noises in front right channel, which would go away if you bump the connectors or the amp itself. So, I took it apart and fixed a lot of cold solder joints, and then put it back together. Well, now the amplifier only shows up PROTECT message and wont let me do anything I checked that there should not be shorted contacts anywhere. I also noticed when I turn on the amplifier, there is over 9 volts going to speaker connections(way over voltage I guess), and on the digital pwb, there is 7805A voltage regulator(IC1009) which goes extremely hot when amplifier is on and showing the protect message. I also checked all power transistors and they seem to be good aswell.
    I'm pretty much newbie with fixing this kind of audio stuff, but it would be nice if I can get this to work Any ideas what could be wrong with this one?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8158
    Re: Sony STR-DE445 wont go out of PROTECT-mode
    You got DC on the output stage (brick is shot) or the bricks aren't making proper contact (more cold solder joints). As long that is there, the amp stays in protect mode. Since the amp was doing some weird noises first in one channel, I would resolder every single pin on those 2 output modules first. After you are done clean up your solder work with pure alcohol and an old toothbrush. You don't want to add potential damage.
    • mtoivanen
      • Sep 2014
      • 9
      • Finland
      Okay, this is getting weird I cleaned up all the solder on those 2 big chips, and applied some fresh solder to them. Also noticed 2 cracked contacts and more cold joints, which I fixed. Still in protect mode, but what I discovered now, left and center channels have 12 volts, and the right channel has -46VOther thing I noticed, on the front panel there is A.F.D and 2CH buttons which used to show orange light, now there is only flash or nothing. I guess one of those big chips or both of them could be faulty?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Well Sir. If it was working before you attempted to repair the cold solder joints. I would conclude that you unknowingly made a short circuit on one of the joints. Retrack your steps. It happens to the best of us, so don't give up. You'll get there with persistence.
        • mtoivanen
          • Sep 2014
          • 9
          • Finland
          Yup, it could be possible too. I take my magnifying glass and check everything with care, hopefully that will help. And yes, it was working, but right channel only made popping and cracking sounds and if I had speaker plugged in to right channel, it would sometimes go to protect aswell, thats why I started repairing this
            Service manual
            • shortfoxyman
              • Mar 2021
              • Ελλάδα
              Hello i have the same problem.....the 7805 on digital module get very hot and it is permanent on Protect Flashing mode. Did you find exactly which is the problem?
              • jm1234
                Solder joints on heat sinks matter?
                by jm1234
                solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                04-28-2024, 04:38 AM
              • crackedprint
                Sony HCD-HX80R Amplifier Volume Control Problem
                by crackedprint
                I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                I have tried a Cold Reset as per the service manual.
                I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                I have looked all the way through the service manual and tried many online...
                01-21-2025, 12:18 PM
              • goodpsusearch
                Sony STR-DE445 did I get a faulty IC?
                by goodpsusearch
                Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
                First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
                So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
                I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
                Also fixed A LOT of cold solder joints and also done some modifications,...
                04-15-2023, 04:16 PM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • abajor
                x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
                by abajor
                I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
                I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
                I found the schematic and diagram for the board here.
                https://www.badcaps.net/forum/troubl...e-devices/sche...
                07-20-2024, 04:46 PM
