Denon AVR 486 Dead
  • tech2014
    • Aug 2014
    • 807
    Denon AVR 486 Dead
    I got a Denon AVR 486 that had water accidentally spilled in the unit. It is completely dead, no standby or any display. Anyone have experience with denon receivers with no power.
    • 31026
    Re: Denon AVR 486 Dead
    foto's please.
    • tech2014
      • Aug 2014
      • 807
      update- The power does come on now but relay RLY106 keeps clicking non stop and after a while the display flickers as well. Here are pics of the unit.
      • hepha3stus
        • May 2015
        It looks like the board is still wet/damp in the last photo, is it?
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
        • Data45000
          Denon AVR-X2600H DAB - HDMI Ports dead
          by Data45000
          Hi there,
          I just wanted to watch another episode of Luficer last night and had turned on my AVR with the FireStick.
          Suddenly I heard a dull bang. "Poof"
          I noticed that several HDMI inputs no longer work at all. Some only work when a PC signal is present or only one signal on the whole input side.
          Often the picture goes black or it jerks up and down as if the signal is present briefly, but then disconnects in a loop.
          However, the front HDMI works perfectly...
          Would anyone have an idea what is defective here...
          04-17-2023, 04:59 AM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
        • nobbnobb1
          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
          by nobbnobb1
          Hi guys,
          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
          02-03-2022, 11:14 AM
