Recommendations Bad Caps Bose Radio Always On?
  • KenOlson
    • Jun 2011
    • 81
    Hi
    A friend inherited a Dead Bose Wave Radio.
    Have been researching this radio and recently watched Chris Cuff's Excellent Bose Radio Videos https://www.youtube.com/watch?v=hysws_wx5WU https://www.youtube.com/watch?v=BA9t64x_2RA
    Every Cap BAD!
    Googled "Bose radio bad capicators" and found "Thoughts on used Bose wave radios" http://antiqueradios.com/forums/view...p?f=2&t=230134
    Similar findings: caps "are ALWAYS on. The on off button is just a mute button. The capacitors in them are mostly low quality."
    Appreciate recommendations concerning cost effective caps for Bose Radio?
    Ken
    • 31015
    Re: Recommendations Bad Caps Bose Radio Always On?
    when in doubt - panasonic FR series.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      ahh, the radio forums! im a member!
      Bose refused to make any service manuals available so i couldn't tell you what stock of caps to get or what is compatible.
      Follow the white rabbit.
      • KenOlson
        • Jun 2011
        • 81
        stj & goontron,
        Thanks for comments.
        Since post found "Bad Capacitors Strike Again" http://blog.kf7lze.net/2013/02/05/ba...-strike-again/
        would you please comment on "EM-branded capacitors" mentioned in post.
        Googled but found nothing
        Ken
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          I'm guessing the blackening is chemical. If they are discolored then they need to be replaced. Otherwise, replace the 'lytics and of it sounds odd, then replace the Polly film guys there.
            • 31015
            EM brand - never heard of them.
              by momaka
              03-12-2025, 03:42 PM
            • shelby5041
              clock radio / radio lifespan?
              by shelby5041
              hi
              ive got a modern digital clock radio approx 15yrs old
              my question is how long can a clock radio or a simple radio last ss farcas operating hours?
              since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
              the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
              it uses very little power just a few watts i would imagine that may have something...
              09-14-2024, 03:30 AM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • UserXP
              Vintage SONY Digital Clock Radio ICF-C12W no audio
              by UserXP
              Dear all,
              I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
              i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
              My question is, do you know of this brand of capacitors and how bad are...
              07-21-2025, 08:35 AM
