Aiwa TX-110 Tuner Buttons
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
    Thank you
  • petehall347
    • Jan 2015
    • 4445
    • United Kingdom
    Contact adhesive ,but once its on its staying there .
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Gel or liquid
      • petehall347
        • Jan 2015
        • 4445
        • United Kingdom
        never knew there was a choice
        • DXseekerMO
          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
          by DXseekerMO
          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
          09-15-2021, 05:15 PM
        • Mark R
          Does Changing Out Caps In A Tuner Effect FM Reception
          by Mark R
          "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
          I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
          Any Thoughts?
          06-11-2024, 07:04 PM
        • netgearnetgear
          AIWA 32" TV not turning ON
          by netgearnetgear
          Good day everyone,
          I have a AIWA 32" TV model #
          AW32B4SM that is turning ON with a blank screen. The backlight is working but there is no image on the screen. I did the standard troubleshooting checks: logic board inspection under microscope, reseating ribbons cables, power rail checks, diodes, mosfet checks, power on and measure voltages on coils, caps, vcc, regulator checks all check good. Then I measured the panel voltage (12v present) and noticed that the VONE (approximately 30v) was missing, the AVDD (15v) was only 5v, vcc 3.3v present, vcc 1.8v present. I know when...
          10-03-2025, 06:06 PM
        • oboyled
          AIWA mx-70 distortion
          by oboyled
          Re-curbing the amp , all caps seem visually ok, amp hits distortion at vol level 3, any input. Using aiwa 6 ohm speakers . Any ideas...
          09-04-2025, 11:56 AM
        • bobbyskillz
          Vizio E241i-a1 - works, but OSD stuck and no buttons work
          by bobbyskillz
          Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
          I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
          Thanks for...
          07-02-2025, 03:43 PM
