AIWA mx-70 distortion
  • oboyled
    • Dec 2021
    • england
    Re-curbing the amp , all caps seem visually ok, amp hits distortion at vol level 3, any input. Using aiwa 6 ohm speakers . Any ideas
    • 31156
    how old is it?
    maybe the main smoothing capacitors have dried out.
      • 31156
      o.k. - 30years minimum - probably main caps.
      here's a manual:
      https://elektrotanya.com/aiwa_mx-70_.../download.html
      • oboyled
        • Dec 2021
        • england
        Hi, replaced PSU caps, (2*6800uf) no change. Against schematic both rails were down about +\-6v. All regulated lines were correct. At a loss. Any thoughts.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5012
          • New Zealand
          Excessive current draw pulling the voltage down? And whatever faulty part is also causing the distortion?
          -David VanHorn
          • CapLeaker
            Leaking Member
            • 8290
            Kinda weird that it would distort upwards from 3. I assume both channels? Sometimes you gotta answer with desperate measures like Q21 and Q22 muteing circuit, or hauling out the old oscilloscope and see where this distortion is starting out from. It could be caps and IC, cold solder joints, transistors, a DC OFFSET.
            Good luck!
